February 21, 2025, 02:11:07 PM
DFWM
Can anyone think of a reason why...
Topic: Can anyone think of a reason why... (Read 3934 times)
Cher
Mostly Harmless
September 17, 2009, 05:34:41 PM »
...I shouldn't take a die grinder and remove the internals of a stock muffler on a 999? It's a perfectly good muffler, naturally, but it weighs about 500 pounds and sits roughly even with your shoulders when seated on the bike.
So: Die grinder removal of essentially everything inside the aluminum canister, then re-weld it! Viola, super light, riduculously loud superbike.
Yea.
But would I need a Power Commander since the flow through the exhaust system would be greater?
Inquiring minds want to know
muskrat
Re: Can anyone think of a reason why...
September 17, 2009, 06:10:19 PM »
can I bring my lawn chair and beer to watch?
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Samsonite
September 17, 2009, 06:16:37 PM »
Quote from: lisaboyd on September 17, 2009, 05:34:41 PM
Believe in what the Nike God's tell us........
Suzuki DS 80
Suzuki SP 125
Suzuki GSXR 1000
Ducati M600
Ducati SC 1000
Ducati S4R 1000
Ducati PS1000LE
Ducati 1098S
Yamaha YZFR 1000
Yamaha YZFR 600
Ducati Sport 900 Yamaha YSR 50
Triumph Daytona 600
2006 Suzuki GSX-R 600
shadowcougar1
2007 Ducati 999S "Team USA"
September 17, 2009, 06:24:23 PM »
Hmmm.... let me know if it works. [moto]
Don't know what to say anymore...
fastwin
September 17, 2009, 07:08:25 PM »
The 999's suck at the exhaust. Why is it that all Ducati's sound awesome, except the 999s? Especially the two valve air cooled bikes. Awesome exhaust sound. Tamburinis also rock, as do the newer 1098/1198 bikes. Something about the under seat twin mufflers.
The 999 under-seat muffler box just sucks. I wasted my money on a standard 999 with a full Termi exhaust when I could have upgraded to a 999S with full Ohlins!!!! Always go for the top of the line suspension over a dumb-ass, over priced exhaust upgrade. You'd think I was old and smart enough to figure that out.
Apparently not.
svoloch
too old to remember my titanium member...
September 18, 2009, 02:18:41 AM »
There are multiple threads on ducati.ms and ducatisti about coring the exhaust and what to repack with. I've not seen much about leaving it empty, but I imagine you would be better off repacking it with something super light with some fiberglass on top to keep the already toasty factory pillion warmer from actually toasting your cheeks a golden brown ( please pardon the cheek reference, and rest assured I edited it down from my normal svolochness ).
Search for "coring 999 exhaust" or "cored 999 exhaust". The articles don't reference any issues with change to backflow on the stock ecu, but one guy said the flat spot around 4k rpm widened bit and he "had it tuned out".
As usual, let me know if you need a guinnea pig
-svoloch
Тише едешь, дальше будешь
2009 Streetfighter S
exes:
2006 Sh1t Hot Black Xerox 999 1973 BMW R75/5
2001 BMW K1200RS 1994 BMW R1100S
1974 Guzzi T3 1975 BMW R90/6
1975 BMW R90/S 1973 Suzuki T500
♣ McKraut ♣
touched by his noodly appendage
September 18, 2009, 04:03:45 AM »
i've wondered why you and patrick have kept them uncored for so long actually... i don't know what you're waiting for
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
loves ze desmodromics.
September 18, 2009, 05:09:13 AM »
not sure you'd
need
a power commander with out changing the air into the motor also. i know lots of times folks need to richen up the mixture when the airbox is opened up AND the exhaust is opened up or it will run to lean...and coming from that, also run hotter. So they'd richen it up to avoid damage and keep the motor a little cooler.
♣ McKraut ♣
September 18, 2009, 05:21:47 AM »
Quote from: ato memphis on September 18, 2009, 05:09:13 AM
not sure you'd
need
i don't know...my recent experience with an arrow system resulted in massive popping conditions with the airbox still totally stock...stock filter.
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
September 18, 2009, 05:29:42 AM »
Yeah the popping is often one of two things:
1. Running slightly lean
2. Leak in the exhaust
(Mine came from the latter. The DP reverse megaphones I have/had on the bike never have made a perfect seal).
♣ McKraut ♣
September 18, 2009, 06:00:17 AM »
oh it was both.... it runs SUPER lean, as in i'll even get a pop or two on hard decel with complete STOCK exhaust (it's muffled but i can hear/feel them). and the arrows leaked on the slip fits to the header pipes.
2001 M600 Dark
2005 S2R Dark
2001 M750
1996 900 SS/SP
2005 S4R
- Dallas, TX
September 18, 2009, 06:15:42 AM »
that's where my leak occurs, even with new sil spaghetti headers. I thought it might take care of it, but the fit of the dp conti replicas is just loose. i did just recently pick up a set of sil/ncr titanium pipes and the fit seems to be tighter. we'll see once i get the rearsets on and everything bolted together. (new pipes are still low and need the rearsets as the brackets)
Cher
Mostly Harmless
September 18, 2009, 03:45:55 PM »
Very cool, info. Thanks for the replies; most lead me to believe that this chop/cut/rebuild SHOULD take place. I mean why not? What's the worst that can happen? A totally ruined Ducati motor? Phhh-t. I ain't skeer'd...
September 18, 2009, 04:08:43 PM »
Totally ruined? You mean "opportunity" for fancy motor work.
Cher
Mostly Harmless
Reply #14 on:
September 18, 2009, 04:26:58 PM »
Exxx-cellent, Smithers, I like the way you think...
