April 26, 2024, 09:09:47 PM
Stopintime BOMB q/a - if you have any....
Topic: Stopintime BOMB q/a - if you have any.... (Read 17464 times)
larsson77
Re: Stopintime BOMB q/a - if you have any....
Reply #15 on:
September 21, 2009, 09:42:54 AM »
Nice bike
Reply #16 on:
September 21, 2009, 10:20:05 AM »
StopInTime, I thought you put Brembo Goldlines on your bike from a S2R1000. Am I right or am I confused?
S2R 800 '07
Reply #17 on:
September 21, 2009, 10:58:02 AM »
Quote from: Travman on September 21, 2009, 10:20:05 AM
You're correct - I did, but the pictures are pre brake upgrade this spring
Oooops - in my dreams
Correction:
DesmoDiva
Reply #18 on:
September 21, 2009, 05:18:17 PM »
Quote from: stopintime on September 21, 2009, 05:30:33 AM
but what about me?
You always look good.
'01 ST4 Yellow
'02 ST4s Yellow
JustMike
Reply #19 on:
September 21, 2009, 05:35:26 PM »
Quote from: stopintime on September 20, 2009, 11:40:56 AM
My bike is BOMB from Sept 20.
Off course I'm proud to display it and I will share if you have questions....
Congrats Lars!
Celli
Ducati Codatronca
Reply #20 on:
September 22, 2009, 03:02:24 AM »
Since the pictures were taken this spring I have added some small mods - hockey tape on forks, TechSpec Tank Grips, ForMotion thermometer, raised the rear 10mm and new brakes
Stopintime! Congratulations! Great Monster, great pics!!!
Celli
Ducati Codatronca: Concerto Molto Vivante!
TobyDanger
2007 S2R800
Reply #21 on:
September 22, 2009, 09:16:13 PM »
Congrats!! Inspiration for my own 07 S2R800!
I do have a question, your throttle cam(?) what's the story with that? Billet? 75% turn? Looks trick! My goal, my quest, is to replace as much of the grey/black plastic as I can.
-=TobyDanger=-
"@[=g3,8d]\&fbb=-q]/hk%fg"
S2R 800 '07
Reply #22 on:
September 22, 2009, 10:56:49 PM »
Quote from: TobyDanger on September 22, 2009, 09:16:13 PM
Electraeon Fast Throttle Cam. Yes to all of the above. Show me yours and I'll tell you if it will fit....
colin748916
Reply #23 on:
September 22, 2009, 11:56:10 PM »
You were also he first DMF'er to see it. AFAIK only one other DMF'er has seen it, he's local.
I have seen it. Looks good and sounds like
S2R 800 '07
Reply #24 on:
September 23, 2009, 02:31:24 AM »
Quote from: colin748916 on September 22, 2009, 11:56:10 PM
Yes, and you're the one who brought the DML/DMF to my attention, which has cost me about $10k. It has also doubled the value of ownership, so I guess I should thank you anyhow
crazy bike girl
aka msincredible
Reply #25 on:
September 23, 2009, 04:03:27 AM »
Very nice!
photo FAQ
TobyDanger
2007 S2R800
Reply #26 on:
September 23, 2009, 04:32:03 PM »
Quote from: stopintime on September 22, 2009, 10:56:49 PM
I like the look but I'm not sure about the 75% turn part? How does that affect the drivability on the street? Sounds like it would make it more twitchy? I notice you also have the 14t front sprocket, do they sort of cancel each other out?
-=TobyDanger=-
S2R 800 '07
Reply #27 on:
September 23, 2009, 06:09:45 PM »
Quote from: TobyDanger on September 23, 2009, 04:32:03 PM
Twitchy? I see it as more responsive [moto] True enough, I need to be more aware of what my right hand is doing.
With the limited power of the 800, full throttle is a frequent exercise. When applying full throttle I found that I had to change the grip (raised elbow) before application to avoid an over-rotated wrist (at full throttle). That is not an issue anymore.
My grip/bar input is more relaxed and correct as a result. My arm and wrist doesn't move around as much. I like that.
If you're interested and can afford it - get one and try it?
Scooter-Trash
Reply #28 on:
September 24, 2009, 07:31:46 AM »
Quote from: stopintime on September 23, 2009, 02:31:24 AM
Mwahahahaha. Our work here is done
Seriously, nice bike
numbskull
'07 S2R1000
Reply #29 on:
September 24, 2009, 09:43:28 AM »
Quote from: stopintime on September 23, 2009, 06:09:45 PM
Electraeon's site is a little wonky on my computer. (I can't read it easily because of the font used). Can you tell me what version of the cam you have on your S2R? Type 1 or Type 2?
