Air cooled monster last year?
Started by ducati culture, September 25, 2009, 08:26:05 AM
ducati culture
Greetings Ducers,
What is the last year and biggest CC they made with air cooled monsters.   Yes  NO anit free-free.   [coffee]
Quote from: ducati culture on September 25, 2009, 08:26:05 AM
Greetings Ducers,
Now all monsters are air cooled and biggest is 1100cc.
Or I don't understand your question.
ducati culture
Quote from: mitt on September 25, 2009, 08:35:22 AM
Air cooled only!
Kopfjager
ducati culture
#4
Correct me if I am wrong.  Doesnt the newer monsters run anti-freeze?
Spidey
The new 1100 does not run anti-freeze.  It has no radiator, and no liquid cooling system.  The only liquid-cooled monsters (aka run anti-freeze) are the 01-02 MS4, the '04-'06 S4r, and '07-'08 S4rs and S4rT.  In the current line-up, the Streetfighter replaces the prior generation liquid-cooled monster.
This FAQ on different generations of monsters might help:  http://ducatimonsterforum.org/index.php?topic=25126.0
herm
also, several of the larger displacement air cooled monsters do have an oil cooler, which might be causing some confusion
I'm here for a good time, but not a long time.
ducati culture
Quote from: Spidey on September 25, 2009, 09:28:25 AM
Thanks for the info !  [thumbsup]
Engineernerd time - the air cooled monsters are also liquid cooled (oil), just not water (anitfreeze) cooled.
Spidey
Technically, oil is not a liquid.  It's lubey goodness.  You should know that.   [cheeky]
Quote from: mitt on September 25, 2009, 09:56:07 AM
If we go that route, then it's the 696... Other wise it's the 1100 if you count oil as lubey goodness and not a liquid.
redial
oilâ€,â€,[oil]  Show IPA
Use oil in a Sentence
â€"noun
1.   any of a large class of substances typically unctuous, viscous, combustible, liquid at ordinary temperatures, and soluble in ether or alcohol but not in water: used for anointing, perfuming, lubricating, illuminating, heating, etc.
Not all of them.
The 750s that had the slave on the left side were air only as were all the models less than 900 (620/800).
The 900's were oil/air until FI, I think, when they went to air only...I think.
Dunno about the 1KDS and the 696/1100.
I also don't know about the old case (97) M750.
Quote from: ducpainter on September 25, 2009, 11:59:00 AM
The 900's were oil/air until FI, I think, when they went to air only...I think..
All the FI 900s are air and oil.
Kopfjager
