February 13, 2025, 01:58:13 AM *
Pages: [1] 2   Go Down
Author Topic: oggy knobs - removing  (Read 2427 times)
ollie
« on: September 27, 2009, 03:31:30 PM »
Hi all,
Haven't been around here much lately, been working on another project bike.
But, now that the weather is getting kinder and there is a couple of things I'd like to do to the monster.
The previous owner had installed Oggy Knobs, I don't really like the way they look, sort of interrupts the lines of the frame.
Has anyone had any experience installing/removing oggys?
I gather there is rod which passes through the frame and engine mounts which the knobs are fastened to to, but I suspect that this is not the original engine mount rod as it seems to protrude to far from the frame. If it isn't I fear trying to track down an original rod could be problematic and/or costly.
Has anyone got any ideas?
dragonworld.
I can make like a tripod with my.....
« Reply #1 on: September 27, 2009, 03:56:22 PM »
Yep yer right!!
To install the frame protectors a longer engine mount is used, soooo you'll have to get a standard stud/bolt.  Huh?
You can go the OEM route or work out what the length and diameter requirements are and go to your local nut and bolt man and tell him what you need.
It'll probably have to be made and should at the least have an anti corrosion coating, but I have a feeling in my water that it'll be a tad cheaper than the Duc part. (I stand to be corrected, but on previous general experience , well.... you know what I mean Roll Eyeswaytogo
ollie
« Reply #2 on: September 27, 2009, 04:09:16 PM »
Yep yer right!!
Thanks, I thought that might be the case.
I'm sure getting a bolt made will be cheaper than OEM. As far as anti corrosion would stainless steel be the go or is there any better options?
dragonworld.
« Reply #3 on: September 27, 2009, 04:20:22 PM »
Stainless should be ok but will be obviously more more Exxy!!  Roll Eyes (It shouldnt be too brittle for this application?? Anyone got an opinion?? Grin )
If you using stainless, anti sieze is a good idea, not that you'd be removing it frequently but it assists in stopping corrosion. Grin
Stainless can and does rust. I work on the trains down here and they are mostly stainless and it certainly isnt unusual to see rust on them. Shocked
madalf71
relaxing at home
« Reply #4 on: September 27, 2009, 05:17:30 PM »
Hi Ollie, what bike are they fitted to?
cheers
Madalf
dragonworld.
« Reply #5 on: September 27, 2009, 05:25:07 PM »
Ullo!! Look who's 'ere!! Grin
madalf71
relaxing at home
« Reply #6 on: September 27, 2009, 09:11:58 PM »
Ello Ello, what going on in ere then?
Yes still around Dragon, just flat out on other things.
Cheers.
Madalf.
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #7 on: September 27, 2009, 09:30:27 PM »
do not use stainless!!! nowhere near strong enough for that application. the std bolt will be high tensile and really, you need to use a genuine part. i doubt you will get a high tensile bolt made for the cost of a good 2nd hand genuine bolt, and as long as it's not bent and the threads are good, there's no reason not to use it. plenty of bike wreckers should have them, they're not in huge demand.
refer to the chart to see the tensile strength of stainless.
http://www.boltdepot.com/fastener-information/Materials-and-Grades/Bolt-Grade-Chart.aspx
paul.
refer to th
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
« Reply #8 on: September 27, 2009, 09:55:51 PM »
+1
Do _not_ use some random hardware store sourced stuff just 'cause it fits...
People spend a _lot_ of money for _better_ than OEM engine mount bolts (see here)
I'd check with a dealer first - occasionally Ducati surprise me and price spares sensibly, next I'd check the wreckers (I've had some success with find-a-part in the past, they mail/fax your request out to a whole bunch of different wreckers at once), and if I had the money I'd seriously consider those Nichols bolts.
But _please_ don't just pick something up at Bunnings and expect it to work...
big
Dockstrada
« Reply #9 on: September 27, 2009, 10:51:38 PM »
Hi all,
What Monster you got Ollie, I may have an engine bolt  waytogo
If I wasn't who i was, I wouldn't be who I am !
ollie
« Reply #10 on: September 27, 2009, 11:39:33 PM »
An 05' 620.
Anyone want some oggies??
Dockstrada
« Reply #11 on: September 28, 2009, 12:03:54 AM »
An 05' 620.
Il have  a look tonight  waytogo
mattyvas
« Reply #12 on: September 28, 2009, 01:48:27 AM »
And the Dock spare part bin strikes again, well maybe I think there are 3 spare bikes in his garage (in parts)
tim_golfer2
« Reply #13 on: September 28, 2009, 02:57:03 AM »
An 05' 620.
Hi Ollie
I've got an 06 620 and you've got mail!
Tim
madalf71
relaxing at home
« Reply #14 on: September 28, 2009, 01:06:35 PM »
Hi All.
The DMF goes enviro-friendly! Talk about recycling and clutter reduction.
Re-bunnings bolts, good for holding a chook shed together, that's about it.
Cherrio.
Madalf.
Pages: [1] 2   Go Up
