February 07, 2025, 07:59:49 PM
Please Help
Ducati MOB
Tool Definitions
Topic: Tool Definitions (Read 1727 times)
desmoquattro
Tool Definitions
September 28, 2009, 04:51:08 PM »
Thanks to my friend Joe Pawlowski for this one...
DRILL PRESS: A tall upright machine for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh --'
SKILL SAW: A portable cutting tool used to make wall studs too short.
PLIERS: Used to round off bolt heads. Also useful in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-ups into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes. A metaphor for life, in general.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for setting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into tamper-proof screws and blistering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
Son of a b*tch TOOL: Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need.
My Vices
'09 1198s,
red
Il Diavolo Rosso
'09
KTM
690 SMC (Thumpy)
'04 Yamaha FZ1, The
Blue
Cockroach
'01 900SS,
custom yellow
, (The Bumblebee)
'05 MS4R,
blue
sroberts152
Say hello to my
Re: Tool Definitions
September 28, 2009, 10:43:20 PM »
I thought you meant this kind of tool...
Or...
desmoquattro
September 29, 2009, 04:18:15 AM »
Those are
squids
, Rob...
squids
Quote from: sroberts152 on September 28, 2009, 10:43:20 PM
Figures...Sacramento.
My Vices
'09 1198s,
red
Il Diavolo Rosso
'09
KTM
690 SMC (Thumpy)
'04 Yamaha FZ1, The
Blue
Cockroach
'01 900SS,
custom yellow
, (The Bumblebee)
'05 MS4R,
blue
sroberts152
Say hello to my
September 29, 2009, 08:23:47 AM »
Sorry... let me fix that...
Ahem. Tool:
desmoquattro
September 29, 2009, 09:05:06 AM »
Quote from: sroberts152 on September 29, 2009, 08:23:47 AM
Ahem. Tool:
LOL...a pretty apt description. Here's the plural:
The sad part is that these guys are now Ducati dealers...
My Vices
'09 1198s,
red
Il Diavolo Rosso
'09
KTM
690 SMC (Thumpy)
'04 Yamaha FZ1, The
Blue
Cockroach
'01 900SS,
custom yellow
, (The Bumblebee)
'05 MS4R,
blue
johnc
vīdī, vīcī, vēnī
September 29, 2009, 09:22:31 AM »
cheese and rice dq, i thought for certain you would have posted this photo as example ... perhaps you are saving this as example of mega-tool
p.s.: VOTE for our project monster @
http://www.monsterartcontest.ducati.it/jspcontest/scheda.jsp?id=4
http://www.norcaldoc.com
desmoquattro
September 29, 2009, 09:29:57 AM »
Quote from: johnc on September 29, 2009, 09:22:31 AM
I think
douche
is a better description.
My Vices
'09 1198s,
red
Il Diavolo Rosso
'09
KTM
690 SMC (Thumpy)
'04 Yamaha FZ1, The
Blue
Cockroach
'01 900SS,
custom yellow
, (The Bumblebee)
'05 MS4R,
blue
johnc
vīdī, vīcī, vēnī
September 29, 2009, 10:33:53 AM »
Quote from: desmoquattro on September 29, 2009, 09:29:57 AM
I think
douche
bleh. that was weak ... you can do better.
desmoquattro
September 29, 2009, 12:06:33 PM »
Quote from: johnc on September 29, 2009, 10:33:53 AM
How about a picture? I know you're better with those.
My Vices
'09 1198s,
red
Il Diavolo Rosso
'09
KTM
690 SMC (Thumpy)
'04 Yamaha FZ1, The
Blue
Cockroach
'01 900SS,
custom yellow
, (The Bumblebee)
'05 MS4R,
blue
