February 24, 2025, 01:26:19 AM *
Pages: [1] 2 3 ... 5   Go Down
Author Topic: Visor Fogging, how to prevent it ?  (Read 18082 times)
DoubleEagle
« on: September 29, 2009, 07:01:08 PM »
I was riding Sunday and the temperature dropped to 62 degrees .
My Visor on my Arai Corsair V was fogging badly.
I was having trouble seeing .
I had the chin vents open in both positions and it didn't matter which position I had them in.
I have the breath guard installed.
If I opened the Visor partly it would clear but it let in too much cold air.
I want to ride in cooler weather but I must find a solution to this fogging problem.
Anyone have the answer to this problem ?
Scotzman
Now that's thinking with your
« Reply #1 on: September 29, 2009, 07:22:29 PM »
As I began reading I was thinking, he should just crack the visor open, until I got farther down. Anyways, in the mornings I have the same issue, but I ride with a balaclava type thing over my nose. This does cause my eyes to water sometimes which kind of defeats the purpose, but... That's what I do though, wear it in the morning when it's cold and keep the visor cracked a bit.
DoubleEagle
« Reply #2 on: September 29, 2009, 07:57:05 PM »
Yea, I've done that and had the same reaction with the cold air coming in the partially open Visor causing my eyes to water to the point of not being able to see.
I bought a breath diffuser that I was saving for cold weather , but I may have to get it out for temps in the low 60s .
Dolph    Smiley Smiley
krolik
Yeah, that's me. So what.
« Reply #3 on: September 29, 2009, 09:24:55 PM »
Quit breathing..
 Evil
Quote from: SacDuc
DoubleEagle
« Reply #4 on: September 29, 2009, 09:45:10 PM »
Quit breathing..
 Evil
Did that work for you ?
Dolph
Rameses
*Your Mom* has a Hypermotard
« Reply #5 on: September 30, 2009, 02:06:27 AM »
http://www.webbikeworld.com/anti-fog-visor/
I have one and it works unbelievably well.
You can get both a clear and tinted insert.  Makes switching under differing light conditions easy even when you're not concerned about fogging b/c the inserts are much more flexible than a regular face shield and consequently much easier to carry.
 waytogo
Gator
« Reply #6 on: September 30, 2009, 04:29:51 AM »
Toothpaste.
We use it in our diving masks to prevent fogging.
I tried it on my AGV shield and it worked a beaut.
Try a little near the hinge first so you know its not going to cause any permanent fogging, it has never happened to me but some toothpastes have chemicals in them that could do nasty things.
« Reply #7 on: September 30, 2009, 04:44:31 AM »
some tooth paste will rip that anti scratch coating right off.
You should just buy a helmet with an antifog lens. makes life easier. (some brands really do work)
« Reply #8 on: September 30, 2009, 04:46:16 AM »
Depends in the type of toothpase, some toothpastes have much less abrasives than your typical Colgate or Crest...
JasonV
« Reply #9 on: September 30, 2009, 04:50:47 AM »
So far my Icon helmet hasn't even hinted to fogging, so haven't had this problem.
2009 696 Monster, CF Termi's, Hindsight LS CRG's, (yes that's it, have a lot of catching up to you guys...)
Frosty_spl
02 M750
« Reply #10 on: September 30, 2009, 05:43:40 AM »
I rode to work this morning, it was 49 degrees. No fogging unless I was stopped. I have an Arai rx7.
professor_pro
« Reply #11 on: September 30, 2009, 06:09:27 AM »
In Seattle a 62 degree morning is the start of a very good day! I break out my perf'd gear!  laughingdp
Add in a little moisture & fogging is hard to avoid.
I've found that the product called 'Cat Crap' actually works very very well. I can ride around with vents closed & very minimal fogging that immediately disappears once moving. I bought the small tub like 5 years ago & there's still about half of it left. I've used it through the very worst of weather with excellent results.
http://www.rei.com/product/752088
(I think the product is made from condensed dish soap and something else, but it does work pretty good for me!)
"Life is for having fun, not propping up emotional cripples!"
Current stable: '08 S4RS Tricolore;  '07 DR-Z400SM;  '04 MINI Cooper S;
Past stablemates: '02 620ie dark; '06 Yamaha TW200;  '76 Volvo 242
Triple J
« Reply #12 on: September 30, 2009, 06:17:03 AM »
Get a Pinlock visor for your Arai. It is hands down the best solution to fogging. You'll need a new visor, and then the pinlock insert. About $90 total...but it works flawlessly. No fogging ever...whether moving or stopped...raining or not.
http://pinlockusa.net/
(this is the same product Rameses linked above)
The second best is to get a Respro Foggy insert...but they leave lines on your face, and change the feel of the helmet.
http://www.respro.com/products/racing/road-racing/foggy_mask/
I prefer the Pinlock now, but I used the Foggy for 2 Seattle winters....i.e. cold, and very wet. Fogging isn't an issue with either of these products.
« Last Edit: September 30, 2009, 06:19:20 AM by Triple J » Logged
2003 M1000s
« Reply #13 on: September 30, 2009, 06:37:18 AM »
Breath out your mouth and project it downward toward your chin.  Sounds stupid but it helps.
Jaman
« Reply #14 on: September 30, 2009, 07:45:29 AM »
http://www.helmetharbor.com/Products/ProductDetails.cfm/ProductID/69861
I have something similar to this - don't remember brand or where i got it, but they work well -- the only caveat is, and this may sound odd, but it's a bit difficult to wipe your nose...  but no issues with fogging since I put one in my helmet.
Pages: [1] 2 3 ... 5   Go Up
