A little computer hardware help...please
Started by ducpainter, September 30, 2009, 02:35:19 PM
So the DVD burner in my HP died so I bought a new one from Newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106333
One problem...
I'm a moron...
My computer is IDE not SATA.
My questions are will this adapter solve the problem, do I need any drivers in addition to the adapter, and can I get something like it locally like at best buy or wally world?
http://www.newegg.com/Product/Product.aspx?Item=N82E16812240012&cm_re=ide_to_sata-_-12-240-012-_-Product
JEFF_H
i bet that would work.
doubt they would have the adapter locally
can you swap the sata for an ide with newegg?
Quote from: JEFF_H on September 30, 2009, 02:40:20 PM
Probably for the restocking charge plus shipping in both directions.
Prolly simpler to just bite the bullet and buy the adapter... Then when the computer dies I can use the drive in the new updated used one I score. ;D
il d00d
Mad Duc
What model PC is it? What OS?
Don't get that adapter, if you try to burn CD's it could hork it up. You should get a controller card. It will have a few SATA ports so you can also get a new HD without the need to upgrade the PC if you don't want to.
PA's official Ducati Owner's Club: PennDesmo.org
Quote from: Mad Duc on September 30, 2009, 03:32:23 PM
It an HP 780n running xp pro
Why would it 'hork' up trying to burn? Keep in mind I bought a burner with the intention of burning. ;)
Mad Duc
#6
the adapter has to "translate" IDE to SATA. It take a very very short period of time to do that but when you're burning a CD/DVD that short period of time can cause burn errors. The drive you bought has a buffer which helps thing. Still, it's not an ideal solution. Getting a SATA card will let you burn things faster & more reliably.
Get this or something similar:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816132001
This has 2 internal ports so you could also get a SATA HD. More options for future expansion.
Here's the specs for your computer, you have PCI - Not PCI-x which is more common these days. You need to make sure you get the PCI version if you get a card.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07049&lc=en&dlc=en&cc=us&product=71042#N1218
The controller card seems to be data only.
I also have a power issue.
I'm thinking I should just get an IDE drive.
Mad Duc
#8
They make a pill for that:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812104652
You can get that at any computer place - Best Buy, Radio Shack, etc.
Don't get an IDE drive - it won't be easy to transfer to your next PC nor will it be as fast.
Quote from: Mad Duc on September 30, 2009, 05:04:57 PM
Yup...
but by the time I buy the controller...a sata data cable and the power adapter I'm within $5 of the price of an IDE drive.
Thanks for your input. [thumbsup]
I'll do the math and decide.
cyrus buelton
1999 M750 (joint ownership)
2004 S4r (mineeee)
ZLTFUL
Sorry for the delay in responded to your PM Nate...either one will work. I would lean towards the adapter only because it gives you a drive in the future on a newer computer. Just go with the IDE to SATA adapter and call it good.
2012 Panigale 1199
2003 KTM 640 Adventure
