Chain and sprocket setup
Started by MAXdB, October 02, 2009, 12:06:23 AM
MAXdB
Can anyone recommend a good place to get a replacement set of sprocket and chain for my s4rs (SSS). i checked with the local dealer and it seemed a little steep.
I remember when i had my R1, i was able to get a 520 chain and sprocket set (steel front/aluminum rear) for 150--I realize this isn't a Japanese bike so it may cost more especially with the SSS setup but I thought i'd be able to find something close to that cost.
MikeZ
DarkStaR
#3
I looked up how much a new oem 520 sprocket is from the dealer, they are about $220.  :o
If your intrested, i have used 520 41t rear sprocket from an s2r800.
JEFF_H
the rear sprocket is the expensive part...the front sprocket and chain should be the same prices as your japanese bikes....
also take a look at the Supersprox Stealth for the rear sprocket....it is cheaper than the OEM part or a carrrier/sprocket combo
