New instrument panel cover
Started by ElCap, October 02, 2009, 11:44:08 AM
ElCap
Help!!! I've got a crack in the lens on my instrument panel on my monster S4 which causes water to get in and  short circuit the electronics. Anybody know where I can get a new? Can't find it anywhere on the web, and in the spare part manual the instrument panel is listed as one part. Seem a little unnecessary to but a new panel which cost a lot of dough when all I need is a new cover.
RBX QB
A thought, not backed up by FHE...
Make your own. You should be able to get a piece of acrylic or lexan from a plastic supply shop (something UV stable, be sure to tell them). Then just use a hole saw without the pilot drill to cut a circle same size or larger than the stock one. If it's too large, you'll have to do some sanding. Then install it the same way the stock one was.
I did something similar with some aftermarket taillights, replacing the clear lenses with smoked ones. I don't have a drill press, so I had to cut a piece of wood with the hole saw, THEN remove the pilot drill and clamp the acrylic between 2 pieces of wood, the top one with the hole I just cut. The top one acts as a guide to keep the hole saw on target. Like blasting wamp rats in my T-35. Worked like a charm, and was totally free because my local shop had a broken piece of smoked acrylic that they just gave me.
Okay... so maybe a little FHE.
NoisyDante
Quote from: RBX QB on October 02, 2009, 12:56:14 PM
I too blast womp rats, but in a T-16.  They're not much bigger than two meters.  [thumbsup]
Thanks, I am in the same boat, this was informative.
