headlight problem
Started by 718frankb, May 24, 2008, 02:34:48 PM
718frankb
i run dual 3.5 headlights- this past weekend i noticed that the low beams werent working but the high beams work fine . has anybody else had this problem . im guessing i have more troubleshooting to do but any help would be great.
" THE ONLY TIME I LET GO IS TO GET A BETTER GRIP "
herm
had the same problem a while back with dual lamps, couple times actually
1st time - burned out filiments in both lamps (go figure)
2nd time - loose connection
check the wiring first [thumbsup]
718frankb
headlight switch was coroded, a little contact cleaner and i can see again.
i live 3 blocks from the ocean so im going to invest in a extra can of contact cleaner !
