December 28, 2024, 02:10:29 AM *
Author Topic: Who sells 14t sprockets  (Read 3234 times)
MuscovyDuc
02' M750I.E. Dark - (pearl white)
« on: May 24, 2008, 02:37:05 PM »
Just wondering who sells good quality low price 14t sprockets? (02 m750ie)
Thanks
knightrider
« Reply #1 on: May 24, 2008, 02:45:42 PM »
i would have to recommend chris kelley at ca-cycleworks, http://www.ca-cycleworks.com/ he carries JT and afam sprockets and has excellent service.
1994 M900
m1moto
« Reply #2 on: May 24, 2008, 06:42:55 PM »
+1 for Chris Kelley
2006 S2R1K  |  Red + White  |  Full Carbon Arrows
http://freshbrand.com/
MuscovyDuc
« Reply #3 on: May 25, 2008, 01:34:07 PM »
Just bought one from them waytogo
printman
Check out my a.....
« Reply #4 on: May 25, 2008, 02:56:39 PM »
and you wont be disappointed  waytogo
I'll update this later at a convenient time Thank you for tuning in.....
Norm
hurricanemotorcycles.com
« Reply #5 on: May 26, 2008, 09:29:46 AM »
Keep in mind that with the tighter circle that the 14t makes, it will give you less adjustability for swingarm angle & THE SWNGARM ANGLE & SIZE OF THE SPROCKET IS WHAT CONTROLS WHAT THE FRONT END DOES DURING ACCELERATION & DECELLERATION.
Sorry about the caps, I hit the cap lock by mistake and am too lazy to undo it and type over.
loves ze desmodromics.
« Reply #6 on: May 27, 2008, 05:54:56 AM »
If you are doing the chain at the same time, which is recommended if you have some miles on the bike, replace the front with another 15t, and go up several teeth in the rear.
You need a new chain usually to go up teeth in the rear, but it is worth it. Staying odd-# and odd-# rear ensures that the inny-vs-outy parts of the chain alternate on the same tooth of the gears, providing more even wearing.
Food for thought!  waytogo
MuscovyDuc
« Reply #7 on: May 27, 2008, 01:21:13 PM »
It's only got 1800 miles on it and the chain looks great.
dlearl476
« Reply #8 on: May 27, 2008, 07:37:42 PM »
+1 for Chris Kelley
I was going to recommend AFAM, and if Chris sells them so much the better.
MuscovyDuc
« Reply #9 on: May 29, 2008, 10:20:39 AM »
I just got it in the mail Grin, I want to put it on now! How hard is it to put one of these on?
otter1
« Reply #10 on: May 30, 2008, 03:42:07 PM »
+1 excellent service applause. What size metric socket do I need to replace it? Also, do I need an impact wrench? The stock 15t looks like it was pressed on because the threaded shaft is machined down over the last thread!! Thanks for the help.
MuscovyDuc
« Reply #11 on: May 30, 2008, 08:22:51 PM »
It's on and it's a beast Evil
otter1
« Reply #12 on: June 07, 2008, 06:48:52 PM »
Sorry about the highjack. Put mine on today. I used a 32mm socket and a 18" breaker bar (got both at sears). Had my wife apply the rear break with the chain still tight. To my pleasant suprise, the nut came off no problem. It took longer to remove and replace the chain guards and other items that were blocking the chain than it took to change out the spocket.
