February 12, 2025, 07:45:48 AM
Ducati MOB
Part needed locally
Topic: Part needed locally (Read 1461 times)
Scooter-Trash
Part needed locally
October 07, 2009, 09:44:12 PM »
Hey all,
The
damn brake light banjo
bolt for my front brakes has apparently failed and is no longer lighting up my rear brake.
http://www.motowheels.com/italian/myproducts.cfm?parentcategoryid=116
|Ducati%20Brakes&productID=3643&showDetail=1&categoryID=475|Brake%20Misc&vendoridtodisplay=0&filterFor=&collection=168|European%20Motorcycle%20Parts
Anyone know a shop locally that carries these? Ideally I'd like this fixed for the weekend.
Michael Moore
Testa di cazzo
WebGeeK
Re: Part needed locally
October 08, 2009, 05:32:02 AM »
I got one of those pressure switches when I bought some rearsets a while back and never used it. I have no idea if it'll work, but it's yours if you want it. Lemme go out to the garage and get more info on it.
La nuova moto e il vecchio motociclista :: 2000 Monster 900 (il vecchio) :: 2008 Vespa GTS (doppio) :: 2010 Streetfighter S ("il PastaBusa")
October 08, 2009, 05:54:24 AM »
Will those things work on front brakes with the coffins?
DanTheMan
October 08, 2009, 06:32:01 AM »
If you locate one in the south bay let me know and i can get it for you.
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 M630ie Dark - Sold
2003 CRF175F
1996 Honda CR125R - Sold
Scooter-Trash
October 08, 2009, 06:40:57 AM »
Thanks folks.
Micheal, yours probably won't do the trick as it needs to be a double banjo bolt for two lines. So unless you have some super funky rear break setup
October 08, 2009, 06:45:38 AM »
So this thing just replaces the stock banjo bolt and it has the switch on the end?
Just askin cause I'm tired of the little micro switch & plunger setup.
Scooter-Trash
October 08, 2009, 07:20:27 AM »
Exactly right. It's a combination double banjo bolt and pressure switch (also available in single line model)
The downside: Apparently they are just as failure prone as the microswitches.
Anyone? Bueler? Anyone?
DanTheMan
October 08, 2009, 08:20:17 AM »
Try Nichols, they sometime have used stuff laying around
2008 KTM 690 SMC
2006 749 Dark- Sold
2003 CRF175F
October 08, 2009, 09:39:17 AM »
You can have my micro switch.
Scooter-Trash
October 10, 2009, 10:30:59 AM »
Stopped in at Desmotosport today on my way home from dropping the scooter off for a new tire.
No only was Scott open, but he had the part in stock
Plus he gave me a set of bar ends to give out as part of tomorrow's Monster Challenge!
Scott
And just to make things perfect, I ran into petemg there and he gave me a lift home
Last Edit: October 10, 2009, 10:43:55 AM by Drunken Monkey
petemg
October 10, 2009, 06:50:39 PM »
Quote from: Drunken Monkey on October 10, 2009, 10:30:59 AM
Scott
Amen.
Didn't that work out well!
Oh, and there must have been something in the air there, because as I was outside warming up the S2R, who should roll up but DQ on the Blue Roach. Wild.
desmoquattro
October 11, 2009, 04:16:59 PM »
Quote from: petemg on October 10, 2009, 06:50:39 PM
Amen.
Classic...a very small world.
My Vices
'09 1198s,
red
Il Diavolo Rosso
'09
KTM
690 SMC (Thumpy)
'04 Yamaha FZ1, The
Blue
Cockroach
'01 900SS,
custom yellow
, (The Bumblebee)
'05 MS4R,
blue
johnc
vīdī, vīcī, vēnī
October 12, 2009, 01:51:39 PM »
just shows ta go ya ... no good deed goes unpunished.
http://www.norcaldoc.com
