February 05, 2025, 07:53:45 AM
Twin headlight
Topic: Twin headlight (Read 5558 times)
RZ500
Twin headlight
October 09, 2009, 01:39:15 PM »
I realise this has possibly been done before, though this kit looks new:
http://shop.revercorsa.com/catalog/product_info.php?cPath=3_29&products_id=199
Has any one had any experience fitting it to a 02 S4 or similar?
I don't want to lose the fairing, just fit the twin lights under it.... ugly gaps or likely success?
psycledelic
Re: Twin headlight
October 10, 2009, 06:16:06 AM »
Nice looking kit, but a lot of ugly wires and junk hiding behind that stock, round headlight. With enough determination, I would guess (guess is the key work in this sentence) you can make it fit, but I would, at least, plan on doing some more cosmetic work behind it.
06 S2R800 - the wife
04 999s - the mistress
Charlief
Re: Twin headlight
October 11, 2009, 05:19:59 AM »
l
l
Very good point. I did the twin headlight thing and there is a massive space above the lights that bugged me. I fabbed a piece of textured abs (used in stereo installs) and mounted it behind the lights. I was lucky enough because the headlights had a mounting groove on the back that I used a captive nut on. I'll take some pics if needed.
Setsukosan
This Is A Battleground!
Re: Twin headlight
October 11, 2009, 06:31:15 AM »
Yeah I have been thinking about going with the twin headlight option as well because I heard through the grapevine that it was difficult to install HID lighting on the standard headlight used. Any insight?
corey
'06 Tang/Black S2R800
Re: Twin headlight
October 11, 2009, 07:05:43 AM »
one thing to consider is that that "kit" pictured has this note underneath it....
"Lights sold individually and without mounts."
I'm assuming that means each light is $195, so your looking at ~$400 for both lights?
PLUS mounts... no thanks...
rockaduc
Re: Twin headlight
October 11, 2009, 10:22:40 AM »
Quote from: corey on October 11, 2009, 07:05:43 AM
+1
If you want brighter, go get a PIAA extreme white bulb
http://www.piaa.com/Bulbs/Bulbs-H4.html
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
TAftonomos
is without a monster :(
Re: Twin headlight
October 11, 2009, 12:26:31 PM »
Or, you could bypass his ridiculous markup, and get them here :
http://www.streetfighterdesigns.co.uk/index.php?_a=viewProd&productId=16
MyDucParts.com
TAftonomos
Re: Twin headlight
October 11, 2009, 12:30:39 PM »
Or again, straight from the source. Don't forget to subtract the VAT either. Not cheap, but not RC pricing either....and DIRECT LOL!
$207 in GBP price after you remove VAT = $330 USD
MyDucParts.com
RZ500
Re: Twin headlight
October 12, 2009, 01:37:56 AM »
Thanks for the advice guys. On top of the probable price blow out, I haven't got a reply to my inquiry so.... it looks like the old style tin/metal lights will do the job.
Regarding the wiring loom and connectors taking up lots of space and being messy, isn't this issue avoidable as I have the fairing and so can hide the wiring under the instrument cluster and out fo sight from sideways as the fairing does the rest?
Any pics of duals with the standard bikini fainring would be appreciated, I am hesitant to get the light unit until I see how it has fitted/integrated with the original fairing.... cheers.
Thanks
Last Edit: October 12, 2009, 02:02:25 AM by RZ500
psycledelic
Re: Twin headlight
October 12, 2009, 02:22:55 AM »
Quote from: RZ500 on October 12, 2009, 01:37:56 AM
Thanks
Not sure if this helps you or not, but below is a picture of the party behind my headlight. Even with some routing and tucking, it is still a bunch of loose shit that isn't noticed because it gets smushed behind a 7+ inch (i think) diameter headlight. Replace that with two 3+inch diameter lights and there are gonna be a serious gap above center of the two (and stuff hanging below). The gauges will hide from the cockpit view and the fairings will hide from the side, but head on is where it will be visible. Honestly, I don't know how visible things would be head on, I just thought it would be worth bringing to your attention before you slapped new lights on, stepped back to admire your work, and had one of those "ah make the beast with two backs" moments that all of us have experienced a time or two.
NoisyDante
I am Jack's
Re: Twin headlight
October 12, 2009, 07:51:32 AM »
I don't have a fairing to cover anything up, but I recently installed a set of dual headlights. I was able to be very clean with the wiring by using looms and zipties. There is obviously a gap between the gauges and where the lamps come together, but having an all black bike helped me in this case.
Those lamps if indeed sold separately seem very expensive. So far I am happy with the 5 3/4" set I got from Aztec8, though I wish the fork brackets were a little more substantial.
'07 695 Dark - Quat-D Ex Box exhaust, gold S4 forks, Woodcraft Clipons, CRG levers, KTM headlight, Motodynamics taillight, 14t sprocket, CRG LS mirrors, flamethrower, the usual refinements. * struck down by a hippie in a Prius on September 22nd, 2010.
TAftonomos
Re: Twin headlight
October 12, 2009, 10:37:39 AM »
Did anyone even read the post I put up there? $330USD from the MFG for both lights and the brackets.
Why do I bother....
MyDucParts.com
Monstermash
AKA-TomColore
Interferiscalo se potete
Re: Twin headlight
October 12, 2009, 06:37:48 PM »
If you want to do the twin headlight setup, check this out...
http://www.monsterparts.com/pc/DUALS/Electrical/DUALS.html
I've seen these on a few bikes nad the quality is top notch. Plus Jeff at Monster Parts is awsome!!!
RZ500
Re: Twin headlight
October 12, 2009, 08:54:24 PM »
Quote from: Monstermash on October 12, 2009, 06:37:48 PM
That's fine, it's exactly what I am looking for and sold from the UK and the US, so it's just a case of seeing which has the best rate conversion and shipping rates.
My only question now is: where can I find a pic of the twin headlights installed with a standard bikini fairing - how well do they integrate together?
Charlief
Re: Twin headlight
Reply #14 on:
October 13, 2009, 05:13:25 PM »
Here's a picture of my bike with dual light.
Like the ghetto hand gaurds? They were a joke.
