Replace plug wires with...?
Started by Mr Earl, October 11, 2009, 05:30:18 PM
Mr Earl
Let the winter improvements begin!  I'd like to replace the plug wires and boots on my M800.  There have been a few posts here and you-know-where about this, and it seems that some controversy exists.  Should I just go down to the local speed shop and pick up some yellow or blue or orange super-duper wire and call it good?  I'd sure appreciate any FHE and smart-guy insights.  Thanks.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
How about these from our sponsor Chris Kelley?
NGK racing spark plug cables for use with BLACK OE Carbed Monster, SS 8515 $39.00
http://www.ca-cycleworks.com
Also make sure the wires separate from the coils, this was an issue on some of the old carbies.
Mr Earl
Thanks for the link, but the M800 is an FI motor.  I know Chris says that the wires don't separate from the gray coils, but a how-to on wire replacement on TOB (http://www.ducatimonster.org/forums/tech/135017-2v-air-cooled-monster-ignition-spark-plug-wire-upgrade.html#msg669284) showed them screwing on to a threaded post inside the coil of a 2002 M750ie.  I haven't checked this yet on my M800, took it on faith.
CairnsDuc
I bought a set of these from TPO parts, and have been very happy with them so far.
http://www.tpoparts.com/catalog/product_info.php/cPath/25_28/products_id/43
That's on a S2R 800 (07)
scott_araujo
I have an '03 M800.  I got some ignition wire at the local Napa and screwed it into the existing caps and coils.  It's silicone rubber so it's more pliable than the original.  Only cost a few dollars.
Scott
