February 05, 2025, 04:48:59 AM
On Swingarms. (Metmachex is getting an A+ in Customer Service so far.)
Topic: On Swingarms. (Metmachex is getting an A+ in Customer Service so far.) (Read 19883 times)
loves ze desmodromics.
Re: On Swingarms. (Metmachex is getting an A+ in Customer Service so far.)
Reply #15 on:
October 13, 2009, 05:12:34 PM »
Note, the Febur 900SS swingarm is 2200....EUROS. eegadz.
Reply #16 on:
October 13, 2009, 08:42:25 PM »
Quote from: ato memphis on October 13, 2009, 11:02:36 AM
~snip~
The eccentric example I've looked at online had notches, and perhaps you tension chain, and make sure the marks are the same on both side? That seems kind of low-tech...
Not really much different from the janky Ducati setup on the non-S*R Monsters.
The eccentric setup on the Paso was designed to use a special tool.
It didn't turn very easy, but the bike had spent a while outside and/or in a harsh environment.
I'm sure it worked a heap better when it was new.
DucHead
No garage queens
Reply #17 on:
October 14, 2009, 02:08:52 AM »
Quote from: Travman on October 13, 2009, 04:21:15 PM
Don't forget JMC. They make a swingarm for the 900SS and one for the Monster.
http://www.swingarm.com/swingarmgallery.aspx
JMC is swingarm.com
Quote from: pompetta on October 13, 2009, 10:49:10 AM
If memory serves (albeit from swingarm.com), there's a tool that fits into
one
eccentric to rotate it. It seems to me that would rotate the two eccentrics differently. I'm pretty sure that I'm missing something.
"45"
Reply #18 on:
October 14, 2009, 04:32:40 AM »
I got updates.
The Metmachex swingarm includes axle and uses the woodruff key setup to make sure both are the same. That would be like the Paso unit above, and making sure both sides are the same approximately zero hassle compared to the stock "lotsa hassle".
There is a 10mm hole on each side to fit rearstand spools/bobbins, which is good news - I like spooled swingarms far more than I like rubber-armed swingarms. There, I said it.
There is conflicting answers about the fitment of a rear hugger
- Ducati Kaemna says no fit, there customers have just run without it.
- Metmachex themselves says it fits fine, looks like it would be funny in the picture, but everything is the same as stock, so chain guard and hugger go right on no big deal.
Plain and simple, I can see why there is confusion. There are no less than
three
rear huggers for the hooped swingarm series, Monster Specific (from Motowheels):
93-94
95-99
00-01
Also the 851/888
So that's nice and confusing. I've got the 95-99 part, let's cross our fingers and hope.
In other news, for those of you following along that are interested in you ST-framed Monsters, Metmachex also makes a swingarm for you, AND they also make a single-sided swingarm for you.
Ducati ST2-4 (and thus Monsters sharing those frames):
And the standard replacement for ST2-4/Monsters:
http://cgi.ebay.de/Metmachex-Aluminium-Schwinge-Ducati-ST2-ST4-Monster_W0QQitemZ290276975719QQcmdZViewItemQQptZMotorrad_Kraftradteile?hash=item4395db2467
RB
Reply #19 on:
October 14, 2009, 05:18:43 AM »
A good friend of mine has a Metmachex swing-arm on his SV650. He had nothing but great things to say about them. He has the eccentrics.
S2R
FLAT ORANGE
Reply #20 on:
October 14, 2009, 07:11:10 AM »
There are also custom one-off options available...
Reply #21 on:
October 14, 2009, 07:51:28 AM »
For my SS plans, I'm looking for definitely custom pipes, kind of like ArcFab used to make that were 'undertails'. And I'm still trying to figure out how to get supermono bodywork. I've seen the airtech streamlining kit, but heard the quality was only so-so, and I need no headlight openings (at this time).
Quick shot of an inspiring ride, then back to swingarms (i can't believe i nearly began to threadjack my own thread)
Kiwihame's '89 900ss: 888 fender, carbon Supermono fairing, Nissan projector beam lights, '95 tank, carbon 955 Corsa tail, 900SSie swingarm (
and a ridiculous amount of other things
DucHead
No garage queens
Reply #22 on:
October 14, 2009, 07:57:40 AM »
Give it a half-fairing so the engine is visible...like the red SS in your swingarm thread.
"45"
Pedro-bot
Reply #23 on:
October 14, 2009, 08:53:47 AM »
Quote from: ato memphis on October 13, 2009, 05:11:41 PM
Yeah, Motocorse.
Won't work with
out frame modification on
hooped suspensions a la 851/888/Monsters. Works with newer ST based monsters though.
Fixed.
Quote from: Duck-Stew on October 14, 2009, 07:11:10 AM
Any pics of it on the bike?
Quote from: ato memphis on October 14, 2009, 07:51:28 AM
That SS looks awesome! More pics or link please.
cduarte
Reply #24 on:
October 14, 2009, 09:07:23 AM »
Quote from: ato memphis on October 14, 2009, 04:32:40 AM
the axle on that swingarm doesn't look like it would fit the 25mm wheels standard on late model monsters/ST models, and ideas on that?
RB
Reply #25 on:
October 14, 2009, 09:09:13 AM »
Just spoke with my friend about Metmachex experience.....i remembered it wrong.
He said that the build quality is exceptional, but when it was delivered, they sent two of the same side axle nuts sliders(or cups), and no chain slider that was to be included with the purchase. He did not opt for the eccentric, due to some reviews he read, even though it looks trick.After delivery of the swingarm he said it was very difficult to get them to send the correct side nut and chain slider. He received the nut but not the slider, he then just bought a slider later out of frustration.
As as he said, this wouldn't have been an issue if they were local, or even in the US, as shipping is cheaper, and hours of communication are tolerable. Alos, this was a swingarm to fit an R1 wheel on an SV650.
So what i am really saying is...Have Duck-Stew make one for you, support our resident flounder.
I am sure that Metmachex does fine business and my friends experience is probably isolated....just though i would bring it up.
there is also
http://spondonengineering.co.uk/
swing arms
Last Edit: October 14, 2009, 09:11:03 AM by RB
S2R
FLAT ORANGE
RB
Reply #26 on:
October 14, 2009, 09:12:55 AM »
Quote from: cduarte on October 14, 2009, 09:07:23 AM
it looks like the same size nut as my S2R....and that is 42 or 46mm something huge. That bike BTW came stock with a DSS, so he/she would need to purchase a different rear wheel.....if that is what you meant.
S2R
FLAT ORANGE
Reply #27 on:
October 14, 2009, 09:20:58 AM »
Quote from: Pedro-bot on October 14, 2009, 08:53:47 AM
Not yet. It's not finished yet. The hexagonal aluminum adjuster plates need to be milled still and the slot for the 17mm axle need to be machined too (as well as a few more things...)
Reply #28 on:
October 14, 2009, 09:23:54 AM »
Quote from: RB on October 14, 2009, 09:12:55 AM
he may be talking about the DSS pictured next to that one, that's a direct replacement. Not sure if is shown with the 17mm axle or the 20mm or the 25mm
Reply #29 on:
October 14, 2009, 09:45:40 AM »
Link is in post, below pictures, reproduced here:
http://www.ducati.ms/forums/showthread.php?p=457632&highlight=888#post457632
