January 09, 2025, 08:27:18 PM *
Author Topic: Common problems or poor maintenance  (Read 1788 times)
haucker123
« on: October 13, 2009, 07:16:27 PM »
Hey, i am looking at buying an 01 ducati monster dark 900cc and was wondering if there are any common problems or poor maintanence areas i should look out for
« Reply #1 on: October 13, 2009, 07:21:18 PM »
Dents in tank sometimes cause leaks at the tank seam.
Be sure and visit the Introduce yourself part of the forum.
loves ze desmodromics.
« Reply #2 on: October 13, 2009, 07:34:56 PM »
'01 is a Fuel Injected Monster. It makes a good deal of power and torque. The motor is fairly robust, there are no common problems that pop out in my head.
The model, being a dark, will have shitty suspension. Consider upgrading these bits early in your ownership to enjoy the other features of the bike.
People have a nasty habit of leaving the fork reflectors on there, which is like a 2hp loss from the get go. Make sure to yank those off.
« Reply #3 on: October 13, 2009, 07:39:33 PM »
If you don't know when the timing belts were last changed and the valves were adjusted or if the belts are over two years old you need belts and a valve adjustment.  Also check the age of the tires.
rockaduc
« Reply #4 on: October 14, 2009, 12:50:09 AM »
+1. Ask where they had the major service intervals done: 600mi, 6k, 12k, 18k, etc. (unless they performed this work themselves).  They should be able to produce receipts.
« Reply #5 on: October 14, 2009, 04:39:33 AM »
You didn't say how many miles, might want to investigate the clutch for slippage as well
haucker123
« Reply #6 on: October 14, 2009, 07:51:38 PM »
Excellent feedback! thanks!
