February 24, 2025, 01:13:59 AM
Cost Cutting
Topic: Cost Cutting (Read 2577 times)
RetroSBK
Cost Cutting
October 15, 2009, 07:13:17 AM »
I hear this topic brought up time and time again, and I wanted to ask what areas do you, as riders and Ducati owners see on your own bikes as where there were corners cut, and if it made a difference to you - When you bought the bike, and now.
The obvious areas, like cheap, non adjustable suspension, chains, and tires come to mind, but what else?
If you look at your bike, what areas do you think could be cut more without you noticing?
Will Kenefick's Retro Superbike. Bringing you the sickest Sh*t since '94
superjohn
Re: Cost Cutting
October 15, 2009, 07:22:11 AM »
Are we talking blatant "screw quality, we need cheap"? Or design and manufacturing efficiencies as well?
Having only 2 core engine families to share the major tooling costs across the entire product line would be efficient, IMHO, but not cheap.
Lower plastic quality, the aforementioned suspension shortcuts, and all I do consider cost cuts. They didn't really affect my buying decision at the time, but some of the items didn't wear very well. Some have failed prematurely. Some I just replaced with a better looking component.
wbeck257
Porkchop Sandwhiches!
Re: Cost Cutting
October 15, 2009, 07:22:50 AM »
Well, they already cut cost on the S2R1000's a bunch:
1. Shit ECU.
2. Bad Valve Guides.
3. Magic Expanding Tank.
I guess they could of used magic puddy instead of welding the frame...
2006 Ducati S2R1000, 1974 Honda MT125, 1974 Penton Jackpiner 175, 1972 Yamaha R5
Triple J
Re: Cost Cutting
October 15, 2009, 07:38:47 AM »
Quote from: wbeck257 on October 15, 2009, 07:22:50 AM
1. Shit ECU.
I don't think any of those could be considered cost cutting measures...more like the opposite. Valve guides and expanding tanks seem to be supplier mistakes. The ecu problems are related to EPA/EU restrictions.
JEFF_H
Re: Cost Cutting
October 15, 2009, 07:43:00 AM »
non-adjustable, non-rebuildable Marzocchi forks
IdZer0
BE
Re: Cost Cutting
October 15, 2009, 10:52:07 AM »
I don't know if you can really call it cost cutting, after all I got the budget version.
This I knew when I bought it:
- non adjustable forks
Now these things bother me and I wish I had bought the S2R1000 in stead (just 2500€ more)
- no bikini fairing & seat cowl (after all it's just plastic and the price is rediculous)
- non adjustable levers
- only rebound adjustability on the shock
- non adjustable ride height rod
- 2 piston calipers
- wheels/rotors: because of the weight & if I want to upgrade to 4 piston calipers I need new rotors (and even then I think mine have 5 bolts and the 320mm discs have 6 but I'm not sure)
This is debatable but I consider the oil cooler a real cost cutter; they say it was designed for the temps it's running but clearly the melting paint says otherwise. I'm not really complaining though as I got a DP ECU out of it and it runs much better now than it ever did with the original ECU.
replaced by 2011 848 EVO
corey
'06 Tang/Black S2R800
Re: Cost Cutting
October 15, 2009, 11:39:08 AM »
Quote from: IdZer0 on October 15, 2009, 10:52:07 AM
320mm rotors with 10mm offset are what you need. They come in 5 bolt, and are on most ducatis.
The 848 and 1098 use 6 bolt.
Re: Cost Cutting
October 15, 2009, 11:44:56 AM »
Quote from: Triple J on October 15, 2009, 07:38:47 AM
I think the switch to plastic tanks was definitely a cost cutting measure.
The fact that what they bought didn't work was a engineering failure...either theirs or the vendor.
Ducati must have spec'd the guide material. If it was substandard it's engineering again. If the supplier cheaped out it's QA that's to blame.
Bottom line is every decision made in manufacturing is a cost based decision.
Drjones
Re: Cost Cutting
October 15, 2009, 11:57:38 AM »
Dock-to-stock inspection methods. i.e. taking the word of your vendor that the part is within tolerances and materials meet the certs.
"Live like no one else now, so that you can live like no one else tomorrow."
"Wealth is more often the result of a lifestyle of hard work, perseverance, planning, and, most of all, self discipline.”
"Helping poor and suffering people is compassion. Voting for our government to use guns to give money to help poor and suffering people is immoral self-righteous bullying laziness."
Re: Cost Cutting
October 15, 2009, 12:16:00 PM »
Quote from: Drjones on October 15, 2009, 11:57:38 AM
That rarely works for any company for long.
Re: Cost Cutting
October 15, 2009, 12:48:59 PM »
Not enough time sorting the EFI maps on the S2R1000's. Some run great, others hunt all the time... It's sad to see really.
+1 to the Plastic tanks. My G/F's 620 has one and I'm collecting bits to retrofit it BACK to a steel unit.
loves ze desmodromics.
Re: Cost Cutting
October 15, 2009, 06:11:08 PM »
I wish they'd standardize some parts. That would save money considerably.
An example would be wheels --> Make all front wheels run the same axle size, same bolt pattern for rotors, etc. Then make all front wheels uniform. Similar, all DSS rear wheels and SSS wheels should be uniform. Volume economics to drive price down. Colors could change, that's fine, but the wheel itself would be an easy way for them to do it.
Likewise, uniform front brake rotors and calipers and masters. That shouldn't change --> Its a ducati, give all ducatis the same, high end brakes. The top shelf model can get the specialty billet units if so needed to differentiate it.
my 2c
cduarte
Re: Cost Cutting
October 15, 2009, 06:32:30 PM »
Quote from: corey on October 15, 2009, 11:39:08 AM
actually, it's the other way around
cduarte
Re: Cost Cutting
October 15, 2009, 06:42:10 PM »
Quote from: JEFF_H on October 15, 2009, 07:43:00 AM
agreed, they really really suck...
Re: Cost Cutting
Reply #14 on:
October 15, 2009, 07:10:05 PM »
As a rider, ive always been cost cutting...
I...
a) do my own work whenever I can
b) I use sport touring tires instead of sport tires (Pilot Road 2ct are the key factor in saving a whole lot of money here)
c) I make with what I have...aka i built my own clutch holding tool, my own bead breaker etc
d) I *now* buy good stuff so i dont have to rebuy it later when it fails.
