April 29, 2024, 04:18:32 AM
Oil Cooler Leak
Topic: Oil Cooler Leak (Read 2102 times)
Duc L'Smart
Oil Cooler Leak
May 25, 2008, 08:10:16 AM »
The ol' Paul Smart developed a leak in the oil cooler- No Bueno!
Here's the main thread-
http://ducatimonsterworldwide.org/index.php?topic=2971.15
All suggestions most welcome
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS,
'73 BMW R75/5
'67 Ducati Monza 250 Bevel Drive
'63 Vespa GS 160
printman
Check out my a.....
Re: Oil Cooler Leak
May 25, 2008, 08:21:00 AM »
as your answer in that thread, a radiator shop should be able to braise a seam. Radiators, oil coolers and trans coolers all work pretty much the same.
Cheaper than getting a new one, but will have to repaint t after though.
I'll update this later at a convenient time Thank you for tuning in.....
Duc L'Smart
Re: Oil Cooler Leak
May 25, 2008, 08:23:19 AM »
Are they braised in the 1st place? Also, I understand that the pressure is much higher in the oil coolers than in a standard radiator. Anyone have an idea how much pressure it needs to withstand?
'73 BMW R75/5
'63 Vespa GS 160
printman
Check out my a.....
Re: Oil Cooler Leak
May 25, 2008, 08:41:55 AM »
between 21 psi hot at idle to 57 psi hot at rpm load 4500+
between 35 psi cold idle to 72 psi cold rpm load 4500+
shouldn't very much at all from these on the PS
And these numbers would be similar to auto numbers and oil coolers also
EDIT: I forgot to add that these are for the 900 motor
Last Edit: May 25, 2008, 02:35:36 PM by printman
Re: Oil Cooler Leak
May 25, 2008, 02:30:11 PM »
Isn't your bike under warranty? Unless it is backordered your dealer should be able to get one in a few days. you could bypass the cooler temporarily. If you choose to go to a radiator shop do make sure they understand the pressure it will be subjected to.
Duc L'Smart
Re: Oil Cooler Leak
May 25, 2008, 07:08:36 PM »
Quote from: howie on May 25, 2008, 02:30:11 PM
Of course not! The warranty expired 6 weeks ago
I'm going to give the radiator shop a try. Should be a lot less than $300., & I'm going to ask for an 80PSI pressure test.
Thanks for the input, I'll keep y'all posted
'73 BMW R75/5
'63 Vespa GS 160
Re: Oil Cooler Leak
May 26, 2008, 04:50:07 AM »
Quote from: Duc L'Smart on May 25, 2008, 07:08:36 PM
Six weeks
I would try speaking to the dealer, can't hurt. If my memory works KTM uses the same cooler and sell it for less. Anybody out there know if I am correct?
Duc L'Smart
Re: Oil Cooler Leak
May 27, 2008, 07:33:54 AM »
Whew! I took the oil cooler to a radiator shop yesterday (yes, they were open Memorial Day), & they pressure tested it, but couldn't find a leak. They went ahead & put a nice fat weld around where I
thought
it was leaking. Did it while I waited... $10.
Got it back together & fired it up, & let it idle for quite awhile. Looking good, so I rode to the gas station.
Got it up to around 8k rpm, & about 210 degrees.
NO LEAK
Thanks for everyone's input
'73 BMW R75/5
'63 Vespa GS 160
