Anyone know where this bracket is from?
Started by Mr.Saturn, October 16, 2009, 12:56:00 PM
Mr.Saturn
Last owner moved it under the seat and drilled some holes for turn signal mounts.  Looked decent, but moved em further back now with a tail chop.  I would like to know where the bracket came from originally however.  Holes in the sides have been drilled, the two in the center are original I think.
Also, does anyone know an easy way to reinstall the rubber filler neck inside the fuel tank on an '05 620?  He pulled that out too and I see no reason not to reinstall it.
This piece:
Not sure where that bracket came from.
No point in reinstalling that rubber filler neck, it'll just fall out again... which is very likely why you have it.
Juan
That bracket came from the license plate assembly.
You don't need it. and that rubber filler I still have mine on, I don't know why they fall in some bikes, I've hear that you really don't need it.
Mr.Saturn
Cloner
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
corey
