February 24, 2025, 01:35:38 AM *
Author Topic: is the 2006 Ducato 1000 cc engine closed loop?  (Read 1693 times)
lwszabo
« on: October 22, 2009, 04:37:49 PM »
in the sport 1000 sport classic?
yotogi
« Reply #1 on: October 22, 2009, 04:52:48 PM »
99% sure it is.
Should be the same engine as the S2R 1000 I believe. The 1000DS.
lwszabo
« Reply #2 on: October 22, 2009, 04:56:57 PM »
99% sure it is.
I was thinking in 06 it was open loop...maybe I was wrong. I guess it dont matter much, if I get one I will get the Termi kit anyway. I just love the Zard look
2003 M1000s
« Reply #3 on: October 22, 2009, 06:02:18 PM »
Look on the parts diagram and see if there is an O2 sensor.
I was thinking open loop for some reason.
« Reply #4 on: October 22, 2009, 06:30:42 PM »
2006 Sport 1000 has an O2 sensor. On the stock exhaust, it's tucked back in the crossover pipe, just before they come under the swingarm.
Yes, you still get the "lurch" if you try to hold it at 4000 rpm. With the stock ECU, keeping your chain tension within specs helps this immensely. As does taking your bike to ducvet. He's, well, magic.
If you go the Zard route, you'll still have to do something about the O2 sensor. Just letting it dangle makes it run even hotter.
lwszabo
« Reply #5 on: October 23, 2009, 04:18:25 AM »
I would go the Termi rout. I dont think it looks as good as the Zard, but it sounds better (IMO) and is almost 1/2 price.
yotogi
« Reply #6 on: October 23, 2009, 06:51:22 AM »
And a DP ECU or ECU reflash to DP spec will eliminate that little devil and get you on the road to tuning the engine correctly.
Speedbag
And the Intrepid
Since 2004!
« Reply #7 on: October 23, 2009, 08:55:43 AM »
What's a Ducato?  cheeky
S2R 800 '07
« Reply #8 on: October 23, 2009, 09:30:41 AM »
http://www.fiatprofessional.no/ducato.asp
lwszabo
« Reply #9 on: October 23, 2009, 01:30:47 PM »
oooopppppssssss!!!! Grin
1KDS
« Reply #10 on: October 23, 2009, 05:25:47 PM »
But that has a 2.2 to 3.0l engine so I'm confused on the 1000cc question
Every bike I've ever owned.
S2R 800 '07
« Reply #11 on: October 23, 2009, 10:38:49 PM »
With an O2 sensor it's only the first 1k cc (1 l) which are affected by the closed loop, so the question is valid Roll Eyes
