Digital Gear Indicator for S2R1000
Started by rendler, October 23, 2009, 02:21:27 PM
corey
Quote from: ato memphis on October 27, 2009, 07:42:08 AM
Isn't that what the motogadget unit does?
yup. no mechanical lines/cables... figures it all out based on electronic signals from tacho and speedo.
pretty slick. not slick enough for $225... i'll just count, thanks.
I can't think of how many times I've tried to shift to 7th though. Sure would be nice. I think its built into the fuel motogadget gauges.
corey
i would rather splurge on the motogadget mini with a trick bracket right above a nice dropped headlight. but then i'd have to get my immobilizer deactivated... which would lead to a DP reflash.... which would lead pods.... which would lead to a dyno tune & PC3.... which would lead to... well, an empty wallet. ;D
djrashonal
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
mattyvas
You can also get the SP Electronics model.
http://www.spelectronics.it/index.php/frontend/english/products/24
they are more $$$ of course being Ey-talian but I have seen them work
and they have a plug'n'play Ducati harness.
turbowagon
#20
I have ordered one by pzracing, probably won't be able to tell you how well it work until next year when weather gets warmer tho  :)
http://www.pzracing.it/webUK/index.php?page=shop.product_details&category_id=15&flypage=shop.flypage&product_id=17&option=com_virtuemart&Itemid=1
FYI, I got a good price here (no affiliation)
http://forums.13x.com/showthread.php?t=219120
motolocopat
Why do you need/want one?
I hardly ever look at the tach, or the speedo for that matter.
Typically just ride at a speed that want get me killed or noticed.
I keep the motors revs at a point where I am just coming into the meat of the torque curve so that at the twist of the wrist I'm off.... this will also have some immediate decompression braking if I find myself having to slow down. Generally about 3500-4000 rpm on the monster.
Fergus
Quote from: motolocopat on November 16, 2009, 04:26:13 PM
Sometimes for me, different road conditions affect my perception of speed (flat/straight vs. twisty). In certain cases, I may be riding by feel and be a bit surprised when I try to shift-up, based on feel, to find that I was already in 6th. Then I figure out I was going a bit fast  :-\. I guess looking at the speedo would cure that and a gear indicator wouldn't help...
turbowagon
I occasionally take the monster to the track and with the gear indicator it just gives a little assurance to be in the optimal gear.
Normally I keep track of my current gear pretty good but sometime after I get held by the slow traffic it messes up my reading.
With the gear indicator I can downshift at higher rpm more confidently without worry about locking up the rear.
tcam33
Healtech also has one. I have one installed on my 696 it works great! http://www.healtech-electronics.com/
RUFKM
Hey dude that's D-U-C-A-T-I!  Add another 2000 revs to your equation and you'll be riding too!  If you want to tool around at 3500 ride the hog.
moto
Protune makes a digital gear indicator that includes a rev limiter light. The come with bike specific wiring harnesses.
Nick is putting together an group buy order for them. You can contact him at nick@motowheels.com
We fitted it on our 1098 project bike.
www.motowheels.com
96 M944
98 900SS FE
01 996R
02 MV Agusta F4 750
05 999R
06 SC1000
07 1098
08 M696
