Digital Gear Indicator for S2R1000
Started by rendler, October 23, 2009, 02:21:27 PM
rendler
Can anyone recommend a digital gear indicator for a S2R1000?
hackers2r
#1
The motogadget sure shift is a slick looking piece.  Check it out. http://motogadget.com/en/sureshift.html
rule62
Quote from: rule62 on October 23, 2009, 04:51:19 PM
Can I get one that goes to 7?
Only if you have the transmission to match...
rule62
That's what I'm talkin' about.   [laugh]
hackers2r
rendler
I guess I won't be getting a digital gear indicator. Was told by my dealer the S2R1000 doesn't have the transmission for it.
DarkStaR
Quote from: rendler on October 26, 2009, 04:03:51 PM
Do you always believe the dealer?   [laugh]
rule62
You can get one.  It'll work.  Kinda a 2 man job to set some up though.  They typically pick up info from the tachometer lead.  It's a process of going through each gear to the shift point, while it's on a stand.  Sketchy.  Why not just count gears in your head as your shifting.  Then... when you try to shift into 7th (like I always do  :-\ ) you know your in 6th.
Simon
Quote from: rule62 on October 26, 2009, 08:37:54 PM
+1, I did this too.  ;D
Bizzarrini
Can't you just pick up the RPM and Speedo signal, and calculate the gear ratio from those?
"As a final touch, God created the Dutch"
Isn't that what the motogadget unit does?
