Will this fit my 620?
Started by Lance Goodthrust, May 25, 2008, 11:17:05 PM
Lance Goodthrust
Looking at a Showa from an '04 s4r. Two questions, will it fit or how do I figure out if it will fit and is this worth it? I have wanted to upgrade my rear shock, but will this need further work? My reason for upgrade is I am 210lbs and am running a stock rear setup. Will this give me the adjustment that I need to customize my settings?
AFAIK, the reservoir will give you a problem.  If your major concern is supporting 210 lbs the most cost effective way to do this is a linear spring for your weight, probably about $100 for the spring.  With the money you save you can buy linear springs for the front.
ducrider45
Quote from: Lance Goodthrust on May 25, 2008, 11:17:05 PM
Is this with the fixed res or the remote res? You will need a remote res to work on the 620.
Thomas Jefferson
Lance Goodthrust
Ah, I see. Thanks for the information...the search continues.
