696 Rear wheel removal?
Started by jakem696, October 26, 2009, 03:34:58 PM
jakem696
Anybody have a step by step procedure on how to remove the rear wheel on a Monster 696?
Thanks in advance.
Jake
09 Dark M696
    Tail chop
    Full Termis exhaust Kit
    14t front
    CRG Bar end mirror
    Woodcraft Rear set
    Belly Pan
88 Honda VFR400R(NC24)
90 Honda VFR750R(RC30)
Remove brake caliper
Raise rear wheel
remove left side axle nut
loosen chain
push wheel forward and remove chain
remove axle while supporting wheel
Installation is reverse of removal
Axle nut torque 83 Nm. Grease,  adjuster screw 8Nm.
Chain slack is in your manual.  Too loose is better than tight.
Did I forget anything?
Big Troubled Bear
Quote from: howie on October 26, 2009, 09:31:10 PM
Wash your hands, before putting gloves on for test ride ;D [thumbsup]
jakem696
Thanks Howie.  That sounds simple enough for me to tackle.
09 Dark M696
    Tail chop
    14t front
    CRG Bar end mirror
    Woodcraft Rear set
    Belly Pan
ScottRNelson
I don't know if the 696 uses the same spacers as all of the other older Ducatis with two-sided swingarms.  However, if they're the same, don't forget that the spacer on the left side goes flat-side against the swingarm.  Unfortunately it looks like it would work the other way and many, many Ducati owners have put it in backwards damaging swingarms and causing other problems.
Here's the little bugger:
