April 29, 2024, 06:43:11 AM
Screw fell out of tach
Topic: Screw fell out of tach (Read 1488 times)
bdub
May 26, 2008, 09:47:53 AM »
2000 900ie dark. The little screw on the face plate worked it's way loose so my tach needle wouldn't fall past 4500rpm. After awhile it just went ahead and fell all the way out. If if remove the cluster can I get to the face of the gauges or is there a way to get through the front, like unscrewing the bezel on the tach? I'm real good at taking things apart but not so good at fixing and getting things back together. Any help will be apprieciated
2005 900ie
now with mivv s'
Y2K M900 ie totaled 10/09/08
knightrider
Re: Screw fell out of tach
May 26, 2008, 12:12:18 PM »
nope, the speedos and tachs are sealed, the only way is to take a dremel and cut open the guage then repair it, and glue it all back together.
1994 M900
bdub
May 26, 2008, 12:49:37 PM »
Thanks for the reply. I got everything taken apart and then started to break it into little tiny pieces but held off on that. Now it's back together with a tiny little screw hole at 4500revs and a tiny little screw jammed up at about 10000. I'll get used to it I quess.
thanks bdub
2005 900ie
now with mivv s'
