February 23, 2025, 10:20:07 PM *
News: Please Help
Pages: [1] 2 3   Go Down
Author Topic: Opinions needed on the 2006 S2R800 Dark  (Read 4081 times)
dennisd
« on: November 02, 2009, 03:30:56 AM »
I introduced myself and stated what I want here:  http://ducatimonsterforum.org/index.php?topic=31446.0
I've never owned a Ducati.  I have owned 17 different bikes over the years and I now want to add a Ducati.  I need opinions on the 2006 S2R800 Dark.  I found a used one with only 1000 miles on it.  Please read my initial post in the link above to learn about my needs.  Since this is a use one, I need info pretty quick.
EvilSteve
« Reply #1 on: November 02, 2009, 04:58:21 AM »
The 1100 may be the way to go for you if you can justify the cost. I owned an '05 S2R 800 for a couple of years. They're a great bike, lots of fun, very light and pretty comfortable too. From what I've read the M1100/696 aren't as comfortable as the older models (I haven't ridden the new ones so I'm basing this on reading about it & sitting on the bike so I may be way off base). I remember my S2R 800 fondly but I'd probably go for an M1100 myself. You can definitely get yourself moving on the 800 and based on your intro post would be fine depending on what you weigh.
Omnipotent Potentate
Personal Pretext
« Reply #2 on: November 02, 2009, 05:07:34 AM »
The S2R 800 is a capable bike, but has some short comings. It was still pretty entry level, so the forms are not adjustable, and the rear shock has minimal adjustments. Also the stock from brakes were 2 piston, on 300mm rotors- which are fairly hum drum. They can be brought to a bit more life with different pads - or a swap to the 4 piston on 320mm rotors is an easy job.
The 800 plants good, no ones had problems with them like the S2R 1000 surge. Decent power, and torque - sounds like it matches to your wants in your other post.
The 800 has the APTC modified slipepr clutch - so you get that, and the very light lever pull. Wet clutch - so if you have ducati clutch jingle lust, the 800 won't grant that wish
On a personal note... the Dark is a sweet look. It'll need a passenger seat cover if it doesn't have one, IMO, but the flat metallic black is SHARP!
Now, vs. an 1100 - I cannot say much. I've only sat upon and 1100. But the shape of the seat and tank... is um problematic for me. Just sitting on it wasn't so comfy and hard braking might requite a little time-out if a foot slipped of the peg and I slid forward at all
EvilSteve
« Reply #3 on: November 02, 2009, 05:11:03 AM »
You're right Yuu but all of these issues can be addressed with mods, who doesn't like mods?  Grin
booger
« Reply #4 on: November 02, 2009, 05:55:58 AM »
I have one and have had a great time with it. It's a good bike, easy to live with and to service. It does lack the high-end suspension and brakes, but you don't need them unless you are breaking the law regularly on public roads or tracking frequently. The stock suspension and brakes are easily as good or better than what you would find on a comparable Japanese bike. Forks are Marzocchi, brakes Brembo, shock Sachs, wheels Marchesini. All these are lower-end components from high-end manufacturers(yes Marzocchi makes some really good other stuff). I get tired of reading people whine about the S2R800's shortcomings when you can't even begin to explore its limits and not lose your license and be jailed if caught doing so. Just hubris mainly, a dick-measuring contest. Most people can't ride at the level they talk. These stock components have been adequate for my purposes, and I ride rather hard because I just can't help it. It's a great bike for what you want it for, and won't bust your wallet at the service intervals.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Personal Pretext
« Reply #5 on: November 02, 2009, 06:34:21 AM »
I went from a 620 (basically the same suspension as the S2R 800) to a kitted 900S - RaceTech front and Ohlins in the back. I have to say, that the 900, all around feels more planted on the road, regardless of the legality or lack there of, of my speed.
Nice Steve... nice.
dennisd
« Reply #6 on: November 02, 2009, 10:06:33 AM »
Well, the S2R800 owner is asking $650 over NADA book value and said he is firm on that.  He is the second owner and the bike only has 1000 miles on it???!!  It has the carbon seat cover, rear mud flap removed and mini stalk blinkers.  Still considering it but I think I'm back to the 1100.  Just can't see myself paying more than book value.
EvilSteve
« Reply #7 on: November 02, 2009, 10:09:01 AM »
Yes, a lot of talk about the stock suspension is BS, *however*, if you're outside the size the stock suspension was developed for by any kind of substantial margin then it becomes much more of a serious issue. Even more so if you're on less than optimal roads.
On my 675, the shock is sprung at ~12.5 kgs, I need a 7.6 kg spring (IIRC), I ride less than optimal roads most of the time. Does the fact that the over sprung rear kicks me out of my seat on sharp bumps still mean that suspension upgrades are a waste of time? For the record anyone who knows about suspension would query what I have on the S2R 800 above & be right to do so. Wink
There's a difference between upgrading for bling & upgrading because there's a reason for it. What it comes down to IMO is that if your weight & riding style are outside the possible adjustments of your stock suspension then upgrading suspension is a valuable mod.
Thanks Yuu, it really was a fun bike. Smiley
dennisd
« Reply #8 on: November 02, 2009, 10:20:19 AM »
Kinda curious Steve, what do you weigh?  I'm 170 so I'd like to compare.
EvilSteve
« Reply #9 on: November 02, 2009, 10:43:31 AM »
Right now I weigh about 155 ish. With gear probably around 170 or maybe 180 with my Vanson once piece. Wink
CairnsDuc
« Reply #10 on: November 02, 2009, 10:48:11 AM »
Quite frankly, I would be suspicious of the whole thing, why after 2 owners does it have only 1000 miles on it, is there something wrong with it?
I know for a lot of people a bike is a weekend warrior type of deal, but surely a 2006 bike should have more miles than that by now.
also being that age, timing belts will need to be changed, also will need a oil change unless it has been done recently, and probably not a bad Idea to get the Shock/Forks serviced anyway, and while they have them apart, get the springs set for your weight.
But if it is only a small price difference to go up to the 1100 Monster, I personally would be getting the new bike (I own a S2R 800 and love it dearly) but I always prefer new, because at least I know what has happened to it from day one.
booger
« Reply #11 on: November 02, 2009, 10:55:34 AM »
I'm not against good suspension. I'm trying to say that for the money the S2R800 is a good bike for its intended purpose and quite reliable. $600 above book for a bike thats 3 years or so old and on its second owner, hmmm. Sometimes it may be better to have a bike that's been ridden. Makes you wonder what kind of maintenance it's had if its owners never gave it any exercise. Some think that just because you don't use it you don't have to maintain it which is not true. I'd look elsewhere. S2R800s are for sale all over the place. One could get a real deal on one of these babies. I'll be letting go of mine soon even.
I'm 162 and consider the suspension a bit oversprung and not as responsive as the more expensive models, but I'm not uncomfortable with it and don't consider it any kind of safety issue. For the money it's an awesome bike.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2008 BMW R1200 GSA
Personal Pretext
« Reply #12 on: November 02, 2009, 11:24:13 AM »
Hmm.. I might keep walking. Though is that $650 of the NADA trade in price, or the retail price? Either way, it's not a rare bike, and not nearly as modified as many of the 800's I've seen for sale - Value proposition just doesn't seem to be there.
And as noted, unless it's been done - you're on the hook for a couple hundred bucks worth of work to sort the belts.
* Just did a quick sweep of the sales on here.
A highish milage, but pristine S2R 800 with arrow cnas and mid pipe was asking $3500
http://ducatimonsterforum.org/index.php?topic=30895.0
There's a yeller one with exhaust and some other goodies for $7000
http://ducatimonsterforum.org/index.php?topic=30285.0
Anotehr nice yeller on right up the road from me
http://ducatimonsterforum.org/index.php?topic=28416.0
« Last Edit: November 02, 2009, 11:34:47 AM by yuu » Logged
EvilSteve
« Reply #13 on: November 02, 2009, 12:00:43 PM »
Agreed. Seems like it might not be worth it, keeping in mind of course that if you want a dark bike you can't just change the plastics on the older models like you can on the new ones. As a general proposition I think the S2R 800 is a great bike but maybe not this specific example. Like I said, I'd probably go for the M1100S if I could swing the cash.
dennisd
« Reply #14 on: November 02, 2009, 12:07:40 PM »
The second owner and only 1000 miles really threw me also.  I agree, I'd rather have seen 10,000 maintained miles than 1000 over 3 years or so.  He did say a shop (not a dealership) had done the 600 mile service.  This bike was only 45 miles away but I think I'm going to keep looking.
The $650 is over top retail value so like I said; I'm still looking.
Now another wrench has been thrown into the works.  I was looking at a local dealership's website checking out their 1100s (that's plural not the "S" version).  I decided to look at the used.  They have an '08 S2R1000 listed with only 100 miles.  I assume it is a leftover that saw some demo time.  They price it $1,000 less than an '09 1100.  Which way would you go?  Were there enough improvements to the 1100 to make me walk away from the 1000?  $1000 dollars off really doesn't seem that great of a deal on a year old model unless they are selling it with full factory warranty.  If that was the case then $1000 could go towards the exhaust.  I'm thinking they might deal more on the 1000.  More opinions needed and thanks for all the help so far.
« Last Edit: November 02, 2009, 12:09:30 PM by dennisd » Logged
Pages: [1] 2 3   Go Up
