Winter storage - what do you do?
Started by jamanta, November 03, 2009, 12:24:02 PM
[roll]
nice.
How old is your bike?  I had a 2000 m900 that sat all winter 3x with no fogging and it was ok.
Possible they used different material for the valve seats?
What do you use to fog?
Quote from: Monsterlover on November 04, 2009, 12:43:02 PM
[roll]
nice.
My bike is a 96...bought used in 2000
I fogged it the first few years...then got lazy with no issues
They were using MBTE in the fuel up until last year when they started using 10% ethanol.
Coincidence?
I'm not gonna chance it.
I use stuff in an aerosol can called 'fogging oil'. :P
scott_araujo
No issues with clogging the injectors?  I've seen some complaints from 4 stroke outboard owners on that.
Scott
Quote from: scott_araujo on November 04, 2009, 01:41:30 PM
Scott
From fogging?
My monster is carbed. My 996 is injected.
scott_araujo
Yeah, I saw some complaints from fogging both carbs and injectors on the outboard forums.  I tend to think it's from spraing too much oil down the intake and then the oil gunking up the small orifices in either.  Just curious.
Scott
jamanta
Quote from: scott_araujo on November 04, 2009, 02:09:16 PM
Scott
so, after all... should i spray the intakes or just in the spark plugs ??
if i spray either way, i shouldn't have to start the bike ever 5 days or so, correct?
my whole point of starting the bike was to circulate the oil and avoid having to mess with fogging the engine... would that not work?
Scott
I've personally never had any issues with the carbed bike and I know Bruce Meyers always recommended it in both carbed and FI bikes. That's where I got my info. I didn't do the 996 or the monster last year. I will do both this year.
He however didn't recommend killing the motor with the fogging oil. Just enough to make the bike smoke from the exhaust.
Quote from: jamanta on November 04, 2009, 02:20:25 PM
Starting the bike and running for short periods causes condensation and creates other problems.
I don't recommend it.
scott_araujo
Yup, fog it and forget it.  Just leave it until you start it in the spring.  Unless you're going to go for a good long ride regularly and really get it up to temp it does more harm than good to start it every few weeks.
Scott
jamanta
Quote from: scott_araujo on November 04, 2009, 02:25:56 PM
Scott
awesome, i will do that.
i will spray into the intake with the bike running. can i spray into one intake or should i do both?
about the battery, would it be ok to leave it on the bike and just have the tender connected?
You need to do both cylinders.
The tender will be fine.
jamanta
Quote from: ducpainter on November 04, 2009, 02:34:31 PM
thanks. sorry for the questions. my first moto-winter :)
Quote from: jamanta on November 04, 2009, 02:44:07 PM
Don't be sorry.
I'd rather answer your storage questions than try to figure out what's wrong in the spring. ;D
positivecarry
How do I get to the intakes on a 2005 Monster 620 (another novice question)?
