Winter storage - what do you do?
Started by jamanta, November 03, 2009, 12:24:02 PM
gage
Quote from: ducpainter on November 04, 2009, 02:34:31 PM
You need to do both cylinders.
The tender will be fine.
If spraying the fogging oil through the throttle bodies you will need two cans (one for each) if equipped set the idle slightly high to ensure that you are really able to get it smoking before killing it.
Quote from: gage on November 04, 2009, 05:12:15 PM
I spray alternately into each bellmouth and it seemed to work fine.
Like I've said in the other thread I got lazy for a while.
There are only two reasons for fogging to hurt fuel injectors:
   1.  Go apeshit with the stuff.
   2.  Blame fogging, but the problem was something else, like misuse of fuel stabilizer.
You can often get away without fogging, but why would you take the risk?  A little work and money verses a lot of work and money?  No brainer to me.
Why would fogging hurt fuel injectors?
The fog spray is delivered through the intake tract, not the fuel system?
What am I missing?
gage
Quote from: Monsterlover on November 05, 2009, 03:45:07 AM
What am I missing?
Exactly  [thumbsup]
jamanta
thanks for all the advice guys, i fully winterized my bike this weekend
filled the tank and added stabilizer, fogged the cylinders by spraying into the intakes, cleaned and lubed the chain and put it on the battery tender. hopefully i'm good to go.
the bad thing is that i found a nail on my tire and i'll need to replace it befer riding season comes :(
scott_araujo
Relax!  Now you have all winter to fix it!
Nice job on getting your winterizing done right.
Scott
fouramdesigns
Winter storage? What's that? I ride the winter.... [beer]
2001 Monster S4, Termignoni/ECU, DP short air box w/BMC filter, Rizoma Zero's front/back, Cookie tail chop, Rizoma belt covers, Evoluzione slave, CF all over
jamanta
Quote from: fouramdesigns on November 09, 2009, 01:09:40 PM
you must live somewhere other than oregon. here it rains pretty much everyday from november until april and it is pretty cold too  [coffee]
fouramdesigns
not as cold, but pretty rainy, Nashville.
scott_araujo
Quote from: jamanta on November 10, 2009, 06:40:28 AM
Lies!  It' Nov 10th and it was only partly rainy.  I made it all the way to work without even getting wet.  I bet there will be a dry day in December too!
Scott
jamanta
Quote from: scott_araujo on November 10, 2009, 07:04:03 AM
Scott
hahah, today right? first dry day in a while.
is everyone here from oregon? seems like everyone i talk to is from here  [beer]
fouramdesigns
I have Olympia ride gear, waterproof/breathable/insulated
jamanta
Quote from: fouramdesigns on November 10, 2009, 07:00:18 AM
cool, i used to live in tennessee. i lived in jackson then i moved close to knoxville
