can i powder coat my oil cooler?
Started by the ron, May 26, 2008, 07:53:15 PM
the ron
i want to powder coat everything. maybe even my motor. but i figured i would start out with smaller pieces. so along with all of the other things i plan on blacking out, i was wondering if i could powder coat my oil cooler, or would the paint inhibit the coolers functioning?  oh, i have an 2006 s2r with a 14 tooth sprocket [thumbsup]
the " powder coat the world" ron [evil]
" If you were directly above him, then how did you see him?"
"...... Because i was inverted."
Quote from: the ron on May 26, 2008, 07:53:15 PM
powder will reduce the heat transfer to the air.
c_rex
don't pc your radiator/cooler.  get some high heat or radiator specific paint instead.  Eastwood makes some good stuff.
silentbob
Buy a 696 and then you wont have an ugly oil cooler hanging down there.   [evil]
the "I think ron secretly loves the 696" bob
the ron
Quote from: silentbob on May 26, 2008, 08:40:21 PM
think what you want my friend. i'm not into sportbikes
the ron [evil]
silentbob
Quote from: the ron on May 27, 2008, 05:10:07 PM
the ron [evil]
Then the 696 will be perfect.  It's slow.   [laugh]
Duc L'Smart
No. Yes.
Unless you live in Northern Canada, then I guess it wouldn't matter...
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
aaronb
#7
i sprayed mine with matte charcoal colored paint this winter, so far i have not had an issue, temps are normal.
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
Its aluminum, right? Is anodizing an option?
Some Dude
Bike Info
99 m900s                                                Sbk forks
41mm FCR's
Dyna coils
944 hi comp pistons
heads ported and polished
larger valves
new valves and cams
aluminum fly wheel & clutch basket
[bacon]        [bacon]        [
Wanwo
I used to work for a firm where I was powder coating auto aircon condensers. They had much finer fins than our oil cooler but they were no problem to powder coat. It's not going to clog up the fins with paint. But, as others have stated it will reduce the coolers heat conductivity a tad. But you're NE right? Shouldn't be an issue.
