Rear wheel spacer needed
Started by TAftonomos, November 13, 2009, 05:56:14 AM
TAftonomos
Pretty much like the topic says.   I went to adjust the chain today and go though the bike to check every bolt......   Rear wheel is .5mm at most away from touching the rear swingarm. I could clearance the swingarm I suppose, but would rather space the rear wheel out 3mm or so.  Right now it could work if I adjusted the eccentric all the way forward and to the top..... But that isn't going to do anything for the handling of the bike.
I do have a lathe, but I'm not sure how you could part off a circle 3mm thick and have no runiut in it unless you could mill it flat?!?
Cut one out of 1/8" sheet.  ;)
That'll be way flatter than you could likely do on a lathe.
TAftonomos
#2
Can I REALLY be that dumb.  Maybe my wife is right, perhaps I overthink everything.
Now, on the drive pins....would I need to make new ones, or just get a longer fastener and fasten them through the spacer?
Oh, and this is where I was yesterday:
Came home tonight.  7lbs 12 ounces of trouble in the future!
PM sent.  I have one available....
Quote from: TAftonomos on November 14, 2009, 02:44:58 PM
CONGRATULATIONS
vaclav
