Swappin' Springs
Started by rule62, November 13, 2009, 10:12:32 AM
rule62
Got a spring compresser.
Got some rear shocks.
Got some wrenches.
Need a vise and a way to keep the bike from collapsing when I take the shock off. (Pretty sure a floor-jack under the engine will do the trick.)
Maybe sometime soon.
Dietrich
I know a place that has a vice, bike stands, and spare hands. ...almost hate to say this in public, but me and mine will be wrenching on bikes at my place on Sunday.  ;)  The Church of Dietrich and the Moto-day Saints.
YellowMonster
If that does not work out you can use my shop.  I used my swingarm stand then then my cherry picker to remove the load from the bike.  Made it really stable/controllable when swapping the rear shock.  I just need to get a long t-handle metric set so I can get to that lower shock bolt easier.
2002 M620
2001 748R
pennyrobber
Quote from: Dietrich on November 13, 2009, 10:23:46 AM
I thought you could only attend if you get the official invite from Rule62.
Michael
How did it work out?
Did you guys get the spring done?
Michael
Quote from: YellowMonster on November 13, 2009, 10:33:30 AM
Clay, I got my spring off last night, no problems. I also didn't even need to use the compressors you lent me -- but you're still an awesome guy for lending them to me!!!
I don't think you need a long t-handle to get the lower bolt. I found a trick that makes it easy. And without moving the rear brake out of the way, or any of the rear set.
Mine takes a 8mm allen/hex head, so I took a socket with an allen head on it, fed it through the hole, then a 3/8 to 1/4 adapter, a 1/4 to 3/8 adapter, and pushed them all together. They were just long enough to stick out a millimeter. I then stuck my 3/8 socket wrench up in there and ratcheted away.
Between that and a 17mm crescent wrench on the nut on the other side, it was off in no time. Although, you need to undo the top bolt first so you can maneuver the swing arm up and down as needed. That way you don't have to remove any parts from the side,
I've taken a lot of photos, so I'm going to post them on the Tutorial forum when I'm done.
Dietrich
Way to go Michael, interested in the ride results.
YellowMonster
Cool, glad it worked out well.
Hope all rides well for you tomorrow.
2002 M620
2001 748R
DG
A 17mm crescent wrench?  Why do I find that funny?
"I'm really busy with something not important."
Randimus Maximus
Quote from: DG on November 20, 2009, 12:39:58 PM
You must be shopping for wrenches at the wrong place.
;D
Michael
Randimus Maximus
Michael
DG
Quote from: Randimus Maximus on November 20, 2009, 02:35:35 PM
;D
What?
Beer wrenches I get.
Randimus Maximus
Quote from: DG on November 22, 2009, 08:03:49 AM
What?
I meant it to read that Michael must shop somewhere special to find a 17mm specific crescent wrench.
