February 05, 2025, 07:47:11 AM *
Author Topic: Harley Headlight  (Read 2166 times)
jimbonerz28
« on: November 13, 2009, 01:33:54 PM »
I swapped my old stock headlight for a Harley headlight I picked up at a swap meet. I like the look but I might miss the fairing.
Old look
The new look
97 M900
04 KLR
S2R 800 '07
« Reply #1 on: November 13, 2009, 01:52:19 PM »
I like the dual look waytogo
One mod leads to the next  Grin  http://www.monsterparts.com/c/Windscreens/Windscreens.html
« Reply #2 on: November 14, 2009, 03:50:51 AM »
just realized how you did that. are the light patterns ok? did you rotate the lights 90 deg.?
DucHead
No garage queens
« Reply #3 on: November 14, 2009, 08:40:36 AM »
Damn, that looks/fits like OEM, nice job!!  waytogo   [moto]   chug
lwszabo
« Reply #4 on: November 14, 2009, 10:02:53 AM »
very nice install
teddy037.2
« Reply #5 on: November 14, 2009, 10:41:52 AM »
+1, I'm curious about that, too. if it works right, then that's kinda neat  waytogo
jimbonerz28
« Reply #6 on: November 14, 2009, 01:11:15 PM »
Yes the light pattern is vertical so the beem is really narrow but I have a solution. I am going to split the inner housings and rotate them 90 degrees. This sould give me a normal light pattern. I am more concerned about the extra voltage, can anyone "enlighten" me to the capacity of the charging system? Will it handle the extra wattage from dual bulbs?
« Last Edit: November 14, 2009, 01:21:32 PM by jimbonerz28 » Logged
97 M900
04 KLR
« Reply #7 on: November 14, 2009, 01:27:47 PM »
You have what looks like an early bike with the single phase system so there isn't a whole lot extra.
How many watts are the bulbs?
jimbonerz28
« Reply #8 on: November 14, 2009, 01:58:47 PM »
The bike is a 97 M900, the bulbs are 55w each on low beam and 60w each on high. Should I unplug one bulb until I upgrade the charging system?
97 M900
04 KLR
« Reply #9 on: November 14, 2009, 02:12:28 PM »
You can't really upgrade the charging system without changing the crankshaft, side cover, stator and rotor. The side cover is also different, as is the regulator.
I believe the wiring is the weakest link.
I run an 80/100w bulb in my bike and have had no problems at all. Just make sure all the connections are clean and tight and don't worry about it.
