February 05, 2025, 08:01:17 AM *
Author Topic: Making my Christmas list ....  (Read 1479 times)
eddyshore
« on: November 20, 2009, 07:02:42 AM »
One of the things I thought about asking for was a 14 tooth sprocket, Is it really worth it and what do you get out of dropping a tooth.  And any suggestions as to what might be the best to go with ? Thanks in Advance
James
I am one fart smella !!
corey
'06 Tang/Black S2R800
« Reply #1 on: November 20, 2009, 07:08:44 AM »
totally worth it, especially considering it's about 25 bucks...
one of our sponsors, ca-cycleworks, has a good selection.
http://www.ca-cycleworks.com/shop/catalog/ducati/chain.html (scroll down)
the AFAM's are nice... but the JT's work perfectly, it's what i have. and at half the price, and considering you can't see them under your sprocket cover... the cheaper the better IMO.
support our sponsors Grin
caboteria
02 M750, 70 R50/5, 06 SV650
« Reply #2 on: November 20, 2009, 07:36:57 AM »
Mostly you get smoother takeoff from a standstill, with much less slipping of the clutch.  Definitely worth it if you ride around town a lot.  You also get higher RPM's for the same speed, which may not be a good thing if you do a lot of highway miles.
For me it was definitely worth it since I don't spend much time on the highway.
Omnipotent Potentate
Personal Pretext
« Reply #3 on: November 20, 2009, 08:21:02 AM »
Dollar for dollar it's probably the best mod one can make, and also one of the easiest to do.
You loose some of the theoretical top end of each gear, but you gain a larger usable RPM range.  It makes the bottom end of the power band less likely to lug, and generally acceleration is a touch snappier.
eddyshore
« Reply #4 on: November 20, 2009, 09:38:12 AM »
Great thanks for the info I guess it is going on the the list ....Ho Ho Holy sh%$ I love my MONSTER!!
metallimonster
« Reply #5 on: November 20, 2009, 09:39:48 AM »
I would suggest getting a case saver with it.
Personal Pretext
« Reply #6 on: November 20, 2009, 11:45:37 AM »
Not a bad suggestion. Case savers like $15. Hopefully you never need it - bit I've seen in person a Duc that was saved by one. It's cheap insurance.
djrashonal
« Reply #7 on: November 20, 2009, 07:18:37 PM »
Whats a case saver? (excuse the ignorance)
Edit: NVM i saw the pics, just the piece of metal above the sprocket...but how does it save the case? if the sprocket comes off?
01 SSSSSSS4 - Sold
'09 Triumph Bonneville
S2R800 dark - searching for
loves ze desmodromics.
« Reply #8 on: November 21, 2009, 06:43:34 AM »
no, if the chain ever brakes and lets go, it'll act like a whip, that case saver is to protect the case from getting ripped open by a heavy, fast moving chain fragment.
djrashonal
« Reply #9 on: November 21, 2009, 07:42:58 AM »
+1, Thanks  waytogo
01 SSSSSSS4 - Sold
