Quite interesting ride this evening
Started by Revax30, November 20, 2009, 02:54:21 PM
Revax30
Ok, so I get off work to and rush home to enjoy a nice ride.  Its not warm here, but who cares, I'm out of the office!  I come to the end of my street and turn right.  Whoa, that it a nasty oil spot, never had the backend swing out like that.  Well, it will wear off shortly.  Nope.  Not oil on the tire, instead its a low tire.  Future note to self, feel tires during pre ride check.  After refilling tire and limping home I find the offender.  I have an industrial size staple stuck in the valley of the tread about 1 inch from dead center.  Question is, is this a repairable situation or a new tire. sorry if this is a newb question but I haven't run into this in my short time on 2 wheels.
edit: I know this is repairable, more looking to see if that is a good idea.
scduc
I was always told never to repair a bike tire. Its not worth it. The one flat that I've had, the tire had an arrow head stuck in it. Cut was about 1 1/2 inches long. So no way to fix. You will probably get mixed thoughts on your situation. Personally, I would get fixed, and buy a new one. Use the fixed one as backup.
i plugged my tire with a patch that had a pigtail works great. but it was just 1 hole.
how many holes did the staple make? if it was just 1 and not 2, id say patch it and forget about it. you can patch it yourelf from the outside for cheap with a kit, or you can patch it from the inside, but youll pay more for someone to take the tire off. if your rims are already scratched up, then just bring it to a car place and tip them a little bit more, and tell them to be careful. itll cost you $20 bucks.
wildbill
No way, if i was gonna patch a bike tire def do the internal, I wouldn't trust the outside patches for a motorcycle.
Quote from: wildbill on November 20, 2009, 04:30:45 PM
They work for a car.
I also had no less than 6 of those in a rear that was then driven from Massachusetts to California.
YMMV.
Revax30
I just went out to check it again to see the air situation.  I t has lost a bit over a couple of hour but it is definitely slow.  From what I can see it looks like 1 hole from the staple. The othe end of it seems free.  When I try to move the staple I can hear it leak so I think it is either the only or primary hole.  The local duc dealer is about 15 mile with some of it as highway.  If I have the tire at 30 psi before I leave, thoughts on riding to the dealer or is that stupid?
1KDS
Quote from: Revax30 on November 20, 2009, 05:11:36 PM
I had a flat early this season, I had my gf follow me in the cage with an air bubble.  Filled it twice in the 25 min ride to the stealership.
Every bike I've ever owned.
outside plugs are fine. the only reason i did inside plug was that i have a tire changer and i just took the the tire off.
its the proper way to do it. But theres going to be countless people who tell you that an outside plug works just as fine. And i know plenty of people who have done the outside plug and are fine. Usually with 2 plugs on the same tire.
jwoconnor
A friend of mine runs his own shop. When a customer comes in with a hole and wants it replaced he patches the tire and puts it on one of his own bikes. He never has to buy tires.
2007 BMW R1200GS Adventure
rockaduc
Quote from: scduc on November 20, 2009, 04:01:27 PM
Am i the only one that saw this?!?!?!?  Where do you ride that you are getting an arrow head stuck in your tire??????
[cheeky]
Quote from: Monsterlover on November 22, 2009, 05:25:34 AM
that's awesome
I haven't bought street tires for years.
I run trackday takoffs my buddy gives me. ;)
They're street tires, not race.
Quote from: rockaduc on November 22, 2009, 05:59:26 AM
[cheeky]
Well duh-Indian country!
darkduc7
get a plug kit and stick it in there. it'll be fine, just trim the end of the plug to be flush on the outside, and youre good.
don't die...don't die...don't die....
BastrdHK
Try Slime, not Fix a Flat.  If it is a small hole it is the cheapest repair possible.  Slime will work well on a tiny staple hole.
Put Slime in, remove staple, pump it up to pressure, ride around the neighborhood for awhile, check pressure again.  Good luck!
M-ROCin' it!!!
