clutch rod length x diameter
Started by He Man, November 22, 2009, 01:32:47 PM
If one had a Monster with the shorter clutch rod, is it possible to just buy a longer clutch rod from the newer bikes (325mm vs 333mm ?) and install it so you could use the clutch slaves without the adapter?
