28mm front axle nut .... socket?
Started by seevtsaab, November 23, 2009, 02:21:23 AM
seevtsaab
Couldn't find a 28mm socket ("local" autozone) for the front axle nut for my Monster.
(found 29mm - not close enough)
is 28mm what everyone else uses or is there a SAE equivalent (1 1/8" is closer than 29mm)
Always dangerous walking into tool sections of larger stores.
battlecry
I flagged a Snap-on truck once and the dealer did not have a 28mm.  Bought an SAE equivalent 1/2" drive socket and it has worked fine for me.
corey
I managed to find a 28mm duralast socket at Autozone.. Bummer you couldn't.
battlecry
i used an adjustable spanner,
you can order a 28mm from nothern tools.com if you cant find it. cheap there.
