Stator Question
Started by Sause, November 25, 2009, 06:27:27 AM
Sause
I fubar'd the engine in my 2000 M750.
I pulled the Fubar's engine and purchased one for a 1997 M750, from a member on this site. The stator in that engine has a different connector then what was on my Fubar'd engine.
My question is, can I just swap the stator?
Also FYI this is the thread that I the 97 M750 Engine from.
http://ducatimonsterforum.org/index.php?topic=27314.0
2000 Ducati M750
  Ohlins Rear
  Clip On's
  Carbon High Mounts
1999 KTM EXC 250
Ddan
I *think* you can swap the stator, flywheel and case from the 2000 onto the '97.  Smarter folks than I will clarify, I'm sure
Ducati Monster Forum at
www.ducatimonsterforum.org
Sause
I took the cover off of the 97 and compared it with the 2000, everything matches until you get around the front sprocket. they are shaped slightly different in that area. I only spent 30 minutes on it last night but I'm not sure if there is a way to get these to work, I might need to somehow rewire the harness to accept the 97's stator...
2000 Ducati M750
  Ohlins Rear
  Clip On's
  Carbon High Mounts
1999 KTM EXC 250
Sause
Throwing the stator swap idea out of the window. It just won't work. What would I have to do to get the two stage stator to work where the three stage was? Two wires going into where three were?
Any ideas?
2000 Ducati M750
  Ohlins Rear
  Clip On's
  Carbon High Mounts
1999 KTM EXC 250
You would need to use a single phase regulator/ rectifier, which could be purchased here:
http://www.ca-cycleworks.com/shop/catalog/ducati/elec.html
scroll down to Battery and Charging
