February 05, 2025, 07:53:24 AM *
Author Topic: Stock S2R rearset on a DSS ?  (Read 1232 times)
IdZer0
BE
« on: November 27, 2009, 01:02:40 AM »
Anyone know if it's possible to use the stock S*R rearset on a DSS monster (specifically a 695)?
replaced by 2011 848 EVO
« Reply #1 on: November 27, 2009, 01:29:41 AM »
ive seen SSS Satos on an DSS. so yes, but im sure you need to do some minor fabing.
Ducatl
« Reply #2 on: November 27, 2009, 08:04:47 AM »
I think the SSS swingarms have a wide machined pivot surface for the rearsets to attach to, the DSS has just a very thin unmilled band.  The other issue I see is that you'd need the pivot shaft/bolts for the SSS to Attach it.  If the width from outside to outside on the pivot mounts of the swingarm is different it's just going to get more complicated, especially if the DSS is wider.
Privateer
« Reply #3 on: November 27, 2009, 11:19:59 AM »
sno duc did it on his wife's bike.
I thought I had ordered Sato's for a 620, when they arrived lo and behold S2R/S4R. After looking I figured out a way. Pulled swingarm pivot shaft, machined some plugs that press in ( 0.001 tight ), machined an end cap. Works well.
Good eye for catching it.  waytogo
« Reply #4 on: November 27, 2009, 05:48:56 PM »
S2R rearsets will work on a DSS bike but you have to use the S2R swingarm pivot shaft.  I did it on a 620 BTW...
Privateer
« Reply #5 on: November 27, 2009, 07:35:47 PM »
there seems to be a decided lack of rearsets for 620's.. this gives me hope.
teddy037.2
« Reply #6 on: November 27, 2009, 07:38:46 PM »
+1
seen it
want it
 Grin
Ducatl
« Reply #7 on: November 27, 2009, 07:42:54 PM »
good to know! Grin
