January 02, 2025, 07:57:27 PM *
News: Please Help
Author Topic: Wanted: S4R Map for Full System, K&N Filter, Open Airbox  (Read 2215 times)
DrDesmo
« on: May 27, 2008, 05:37:10 PM »
Hey guys -
I just picked up an '04 S4R and it has the map for a Full Arrow System w/ K&N filter - problem is it also has an open airbox, which is causing some lean running issues.  Does anyone have a map for a full system, K&N, and open airbox?
Thanks!  [moto]
-Adam
'95 916
'12 800XC
« Reply #1 on: May 27, 2008, 09:05:15 PM »
I'm assuming you've got a PCIII?
If so, what kind?
DrDesmo
« Reply #2 on: May 28, 2008, 04:46:18 AM »
If so, what kind?
Yes - sorry to not have put that in my post  cheeky - I believe it's a 710-411
-Adam
'95 916
'12 800XC
« Reply #3 on: May 28, 2008, 07:28:01 AM »
You *might* find someone that's got a custom map for that combination.
As an alternative, you can try tweaking that map till it runs the way you like.
Whatever rpm and throttle range you think it's lean, try adding 5% to the map, then see how it runs.
DrDesmo
« Reply #4 on: May 28, 2008, 07:30:10 AM »
5% to the #'s in the table?  Thanks!
-Adam
'95 916
'12 800XC
« Reply #5 on: May 28, 2008, 07:35:45 AM »
Just as a note, the 5% isn't a magic bullet.
It should be a big enough step to notice.
If 5% cures it, try going down 2% from there, so then you'd be up 3%.
That's the beauty of it, you can fiddle with it yourself.  Smiley
JohnnyCanuck
« Reply #6 on: May 28, 2008, 07:36:33 AM »
I've got an 04 S4R with an open air box and a K&N, Marving Mid pipe, and cored stock mufflers.  I haven't had my bike put on a dyno but did have it set up with a gas analyser.  I'll try and send you the map if you want.
DrDesmo
« Reply #7 on: May 28, 2008, 08:42:45 AM »
 waytogo  waytogo  waytogo Thanks! My e-mail is in my profile
-Adam
'95 916
'12 800XC
JohnnyCanuck
« Reply #8 on: May 28, 2008, 08:49:29 AM »
No problem.  I'll try and get it to you sometime today.
