February 22, 2025, 11:36:51 PM *
Pages: 1 2 3 [4]   Go Down
Author Topic: reroute starboard oil cooler line  (Read 12683 times)
Staggerlee
« Reply #45 on: February 22, 2012, 07:46:26 AM »
The Socketless stuff would work fine in that application; I've been using it for years for oil coolers, turbos & whatnot on VW's & Audi's and never had a problem.  It's super easy to work with (do yourself a solid and pick up a tube of Aeroquip's assembly lube) and the fittings are reusable forever.
The fittings aren't cheap though, and all the parts you'd need to fab up a set of your own "HM" oil cooler hoses would probably cost pretty close to a set of pre-made hoses.  I went with Fren Tubo lines on my M900 just for that reason.
loves ze desmodromics.
« Reply #46 on: February 22, 2012, 08:04:25 AM »
is the socketless stuff a type of "push-lock" fitting?   Instead of using the two threaded parts of a normal AN type fitting?
corey
'06 Tang/Black S2R800
« Reply #47 on: February 22, 2012, 08:24:27 AM »
yes and no... it's push lock in the sense that you push the tube onto the fitting... but that's it. no secondary piece that locks it in place.
here's a video showing the general mechanics:
http://www.anplumbing.com/page/9
looking though everything, just seems like standard swivel-seal stuff is a more cost-effective and appropriate choice.
also, the push-on hose has a rubber outer, which i worry about considering its proximity to the front header-pipe.
Staggerlee
« Reply #48 on: February 22, 2012, 08:25:11 AM »
Yep:
corey
« Reply #49 on: February 23, 2012, 07:02:27 AM »
I hear yea... Sometimes the knowledge of how to do something—and the experience gained from doing it myself—are a little bit of an extra value to me. Still haven't made up mind, but I'll post up results when I do. waytogo
corey
« Reply #50 on: March 26, 2012, 07:50:59 AM »
one more question... now that I have my lines built, and my cooler painted proper black... does it matter which line goes to which side of the oil cooler?
i know which one goes where (top line from motor goes to right side, correct?), but I'm just curious..
Pages: 1 2 3 [4]   Go Up
