reroute starboard oil cooler line
Started by patorojo, May 27, 2008, 07:38:47 PM
patorojo
Anyone have a picture of a reroute of the right hand oil cooler line so it doesn't go in front of the belt cover?  I am trying to show my dealer what I want done.
Thanks.
Arne Berger
2007 S2R1K
2007 DL650
2005 DRZ400S
flsurfdog
if your dealer is doing it, it's a straight bolt on from the hypermotard oil line.
but if you wanna search around you can probably get one made cheaper.  seen it done although i don't remember where they got the parts
06 s2r1000, Apex Clip-ons, Lowered headlight and gauges, HID high/low, Wasen Design front signals, reflectors removed, Mag Performance clutch cover, Rizoma star pressure plate, open airbox, Spark midpipe, Leo Ti slip-on, tail chop and frame plug blinkers
RB
So you want to spruce up yer ride with some new Oil Cooler Lines? To be wrapped around the 'Correct' side of the engine, you know, clean things up a bit.
It seems, but you will have to verify, that Ducati changed some of the line connectors after 2001. This means that the adapter needed for the engine and oil cooler are the all the same size now, 14mm x 1.5 thread pitch after 2001. This translates into the need for 4 AN-6 male adapters for new lines. I purchased the black anodized fittings, but they are also available in the standard blue, alumuminum and stainless steel.
There are also helpful videos online on how to assemble the hose and fittings.
Part #Qnty Description
9919DFH 4Metric thread male to AN adapter male
AT800106 2"Black"Hard anodized swivel seal aluminum Hose End
AT804606 2"Black"Hard anodized 45Deg. Tube Swivel Seal
AT809106 1"Black"Hard anodized 90Deg Tube Swivel Seal Hose End
35060616ft.Pro-lite 350 hose. Use Swivel Seal hose ends
My invoice #396721, Tom from Earl's told me he would keep my order on file for future purchases.
http://www.anplumbing.com
I am in no way associated with Earl's Plumbing.
very easy install
RB
Norm
or go to a tractor supply place & have then crimp up anything you want.
patorojo
Thanks for the replies everybody   [thumbsup]    I previously found the Earl's fittings and hoses and hope to use them.
Arne Berger
2007 S2R1K
2007 DL650
2005 DRZ400S
flsurfdog
Quote from: Norm on May 28, 2008, 06:23:43 AM
Yeah, I was actually told by Paul at NPR Ducati to go to a mechanic at the dekalb peachtree airport and get some mechanic to put one together for me.  Made it sound like an easy job.  (And if it's good enough for an airplane it's good enough for me)
Juan
#8
Here it is..
and the other side.
bmonty72
I know what one of my next mods is gonna be now!!!
herm
i kind of like the braided line showing there by the belt cover..........just my .02
bmonty72
Quote from: RB on May 28, 2008, 05:37:26 AM
very easy install
RB
Did your oil cooler come black or did you paint or anodize it???
RB
they came black, but i kept a black sharpy on hand to touch up my little scratches.
bdfinally
Hey RB, does your invoice cover just post '01 parts or would an '00 configuration be the same? Thanks, BD
Monstyr
Straight bolt on hypermotard hose, its got the advantage that all the fitting look the same as the OE ones.
The two most common things in the universe are hydrogen and stupidity.
