February 06, 2025, 07:01:23 AM
Please Help
Corey's 2R800 Fork Swap... Now 999 Forks...
5
6
7
Topic: Corey's 2R800 Fork Swap... Now 999 Forks... (Read 19828 times)
corey
'06 Tang/Black S2R800
Re: It has begun... 748 forks on S2R800
Reply #60 on:
January 25, 2010, 05:21:13 PM »
I've also noticed a small "wear" spot on the one fork i bought. It doesn't look like a scuff from a drop, but rather a spot that was worn a little flat and POLISHED shiny by something rubbing... I'm thinking a brake line or speedo cable, or something smooth, but i don't know much about what's up there on a 748... any thoughts? It is on the 53mm part of the fork, below where the bottom triple would be... Not the girthiest part of the fork, but not the narrowest either.
These photos should help, but make the mark look alot deeper than it really is. You can see some residue as well, doesn't look like tarmac to me... The forks seem very straight, and compress and rebound very smoothly and consistently, even from one fork to the other. I'm hoping it's just wear from a brake line or speedo cable like i think it is...
It's like two rub marks, totaling about 3 inches in length (or one olive garden gift card... closest measuring device i had).
The worse of the two is about 3/4" in length, by about 5/16th" in width at the widest point.
thoughts please, i hope these forks aren't a zonk.
the scuff doesn't bother me so much visually, as I can just turn it to the back/inside-ish when i mount it...
also, since this started page 5, please see page 4 for my question about fork oil.
Last Edit: January 25, 2010, 05:26:29 PM by corey
Re: Corey's 748 to S2R800 Showa Fork Swap, Update...
Reply #61 on:
January 25, 2010, 06:05:18 PM »
Looks like a wear mark from a brake line.
Also possibly the speedo cable.
Which leg is it on?
corey
Reply #62 on:
January 25, 2010, 08:12:24 PM »
Glad you said that... I'm not sure what leg it's on, as i received the forks off the bike... is there a way to tell?
The marks had some black residue, which leads me to think speedo cable, as I would imagine that the brake lines were probably braided stainless with clear overwrap?
Reply #63 on:
January 25, 2010, 08:18:14 PM »
Pretty sure the SBK's have the brake line going down on the right side, and speedo cable on the left.
The lower casting that the calipers bolt to will tell you left/right leg.
corey
Reply #64 on:
January 25, 2010, 08:43:22 PM »
Wow. that's easy. It's the right leg.
fasterblkduc
Reply #65 on:
January 26, 2010, 02:58:06 AM »
Quote from: corey on January 25, 2010, 06:21:31 AM
Next question... fluid/oil... what weight fork oil do i need? what brand fluid? i have no clue on this, as i couldn't find much in my book about fluid choices...
Did you buy the springs from Racetech? They have a very good Tech. call line. Call them and tell them what you are doing, and what type of riding you are doing. They will give you a recommended fluid weight, and level.
The thicker the fluid, the slower the compression and rebound. You have adjustments for that but you want a starting point. You will probably want around a 5W.
Atomic Racing
Zalusky Advanced Riding School Lead instructor
2010 partners:
Komodo Gear
, Motorex, Studio299, Moto Primo, Caztek, Chickenhawk
corey
Reply #66 on:
January 26, 2010, 04:34:49 AM »
Quote from: fasterblkduc on January 26, 2010, 02:58:06 AM
Haven't bought the springs yet, but was planning to use RT. Thanks for the baseline. I'm sure they will be able to get me all situated.
corey
Re: Corey's 2R800 Fork Swap... Now 999 Forks...
Reply #67 on:
February 15, 2010, 11:39:32 AM »
Well, as the new title says.... Some fancy TiNi 999 forks on the way... Thanks to Theo
If anyone knows anything about these forks that might stall my progress... let me know
I'm already aware of the fender mount differences
Last Edit: February 15, 2010, 11:42:31 AM by corey
rockaduc
Reply #68 on:
February 15, 2010, 01:01:33 PM »
Also check caliper mount spacing.
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
TAftonomos
is without a monster :(
Reply #69 on:
February 15, 2010, 05:57:58 PM »
I should have the forks off and packed up tomorrow Corey
I'm going to see if I can't get the triples off the monster as well at the same time. Might just ship the forks first, triples to follow shortly after.
MyDucParts.com
corey
Reply #70 on:
February 15, 2010, 06:22:22 PM »
Quote from: rockaduc on February 15, 2010, 01:01:33 PM
Yea i had looked into this, it seems like there may be some differences in rotor offset/pinch, i believe the 999 caliper mounts end up putting the calipers about 5mm further out from the rotor? As long as it doesn't move them CLOSER, which it don't think it can because the rotors on the bike have zero offset, then i'm not worries. My brother has a mill, so we are going to be machining some small spacers
as far as mount spacing goes, these are the proper 65mm mounts.
Quote from: TAftonomos on February 15, 2010, 05:57:58 PM
take your time man, if you want to ship them together, that's fine. i'm not getting to this any time soon. we are snowed in hard core, with more coming down right now. appreciate the commitment though!
Last Edit: February 15, 2010, 06:30:31 PM by corey
goldFiSh
Reply #71 on:
February 15, 2010, 11:50:27 PM »
Send Hooligan Machinist a PM - he made some not so long ago, and may have some spare sets of 5mm spacer. I got mine a little while back and he's done an awesome job on them.
corey
Reply #72 on:
February 16, 2010, 03:58:53 AM »
Quote from: goldFiSh on February 15, 2010, 11:50:27 PM
Thanks for the heads up! PM Sent.
greenmonster
Reply #73 on:
February 16, 2010, 06:12:30 AM »
Quote
Like all said, just wear marks.
Have worse on mine, just mount them so marks are towards front cylinder,
like a 45 degree angle . I haven`t noticed my marks f years now.
M900 -97
MTS 1100s -07
corey
Reply #74 on:
February 16, 2010, 06:36:06 AM »
Quote from: greenmonster on February 16, 2010, 06:12:30 AM
got some different forks now
5
6
7
