Fuel Filter Replacement
Started by Michael, December 05, 2009, 02:23:57 PM
Michael
Is my fuel filter supposed to look this crappy? Or is the "old and yellow" look normal?
And do I need to buy OEM, or can I just get a matching filter from Napa for cheap?
Thanks.
Quote from: Michael on December 05, 2009, 02:23:57 PM
Thanks.
Mike,
I assume your bike is a carb model, and then the answer is yes, go ahead and buy the Napa filter...Or any other brand you like.
Michael
Carburetor = yes
Thanks.
And brand recommendations? Does anyone have a favorite or a brand to stay away from?
[moto]
Quote from: Michael on December 05, 2009, 03:43:01 PM
Carburetor = yes
Thanks.
[moto]
usually, since there's no high pressure in the fuel system, any brand will do, just make sure that the inlet/outlet are in the same positon, if not, buy a longer fuel line...You shouldn't spend more than $12.00 on everything...
DucHead
Quote from: pompetta on December 06, 2009, 02:46:02 AM
http://ducatimonsterforum.org/index.php?topic=698.0
NAPA's fuel filter P/N- 3032
That's for FI bikes I think. It would work, but the lines would be pointed in the wrong directions.
The local autozone has an exact duplicate up on the wall.
Take yours and they should be able to match it.
Michael
Quote from: ducpainter on December 06, 2009, 03:10:20 AM
+1 on this.. They used to have their private label "Deutsch" for a while and then had a closeout, I picked up 2 dozen of those for 99 cents each...
sorry, just had to share.. but they have them.. they are nothing special, just a paper gauze filter.  the discoloration is normal.
Michael
* UPDATE *
$5 at Auto Zone -- new fuel filter!
I also got new hoses (both for the fuel line and the drain lines -- just generic rubber hoses that they cut to length down at Auto Zone) and a pack of hose clamps to replace the break-away kind.
DucHead
erkishhorde
Quote from: Michael on December 07, 2009, 08:58:59 PM
* UPDATE *
Good luck getting the new hose to make that U bend w/o pinching. I couldn't get a satisfactory bend.  >:(
Michael
Quote from: erkishhorde on December 08, 2009, 06:03:59 AM
It was no problem, I just had the guy cut a little bit of extra hose -- just a few inches. And so instead of a sharp bend, I'm able to make a wider curve with no pinch in the line.
dlearl476
How did it all go back together?  I notice from the pic that the inlet is on the opposite sides between the old and new filter.  Oh, and FWIW, I noticed on my '99 that you really don't want to clamp that baby tightly to the tank. It needs to rotate a bit as you raise and lower the tank or it will put a crimp in the line.
I think the "opposite side" bit might be helping with the radius of new to OEM hose as well.  Good on you for replacing it.  I didn't and, combined with the "crimping" I noticed later, my OEM hose split and drained almost an entire tank of gas onto my garage floor one night.   :-\
Michael
Everything went back together really well.  :)
It feels like I'm accelerating better, too.
You're right about the filter needing to be able to turn, but it's not really an issue because the filter is smaller than the clamp. So you can still tighten the clamp screw all the way and the filter will still have room to wiggle a little.
dlearl476
Quote from: Michael on December 10, 2009, 09:48:39 AM
You underestimate my ability to mess up even the most straightforward process.   [laugh]
