February 05, 2025, 11:08:13 AM *
Author Topic: simple clip ons question  (Read 1545 times)
NoisyDante
I am Jack's
« on: December 14, 2009, 03:25:15 PM »
I'm getting ready to install clip ons and I think I understand the bulk of what is needed.  Wanted to clear up a couple things though.  For reference I have an '07 695 w stock coffin masters, headlight is aftermarket as well.
1.  I read in a posting I needed to replace my top triple clamp.  Sounded like it was required, but am I correct that this is really for cosmetic purposes and not a necessity?
2.  When using the stock coffin masters, there's been varying accounts of using spacers at times and not needing them in others.  Where would the clearance be in question?  Reservoirs hitting the gauges?
3.  Brake lines need to be shortened?  Do they really hang out that much more?  Clutch as well?
I appreciate any help you guys could offer, I'm trying to do the mods myself.  I've gone with 50mm Woodcraft's, I am having my gauges lowered, and will be fabricating a bracket for a Superduke headlight as well.
mendoje
« Reply #1 on: December 14, 2009, 03:59:16 PM »
1.  I read in a posting I needed to replace my top triple clamp.  Sounded like it was required, but am I correct that this is really for cosmetic purposes and not a necessity?  Likely cosmetic, but I have an older Monster.
2.  When using the stock coffin masters, there's been varying accounts of using spacers at times and not needing them in others.  Where would the clearance be in question?   Reservoirs hitting the gauges?   Dont know about the gauges on a 695.  But generally, the first bend of the handlebar allows the reservoir to clear the bar.  On clipons the bar continues straight past the coffin, and that's where it might hit.
« Last Edit: December 14, 2009, 04:02:23 PM by mendoje » Logged
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike Smiley)
http://ducatimonsterforum.org/index.php?topic=27788.0
« Reply #2 on: December 14, 2009, 07:09:28 PM »
Replacement of the top triple is for cosmetic purposes.  The lower half of the handlebar clamp is part of the triple.
On some clip ons the master cylinder reservoir will interfere with the handle bar clamp without spacers.  If you call Woodcraft they can probably tell you if you need them.  (978) 297-2977
Whether you need shorter cables and hoses depends on your ingenuity and level of tolorance.
NoisyDante
I am Jack's
« Reply #3 on: December 14, 2009, 07:28:11 PM »
Thanks guys.  I've ordered the spacers from monsterparts just in case.  If the lines need replacing maybe I'll have a shop do that for me.
Does anyone have a cosmetic solution for dealing with the lower half of the handlebar clamp?  I assume this has come up before.
rockaduc
« Reply #4 on: December 15, 2009, 12:26:45 AM »
Thanks guys.  I've ordered the spacers from monsterparts just in case.  If the lines need replacing maybe I'll have a shop do that for me.  You can do that yourself.  It isn't difficult.
Does anyone have a cosmetic solution for dealing with the lower half of the handlebar clamp?  I assume this has come up before. Some guys on here have ground it down, then re-finished the triple.  Looks pretty cool.  Other guys have just popped a speedy moto dog bone top cap on there and called it a day.
Wonked
« Reply #5 on: December 15, 2009, 05:23:35 AM »
I kept the handlebar clamps on my 695 when I went to clip ons, and put a little bar in between them to hold my GPS mount. Looks intentional, but it saved me tons of money on a strictly cosmetic mod. I just installed the Apex clip ons (actually, Ducshop in Marietta did). They required spacers, but no additional modification to install.
Latinbalar
« Reply #6 on: December 17, 2009, 08:30:58 AM »
+1 i Cut the original bars so that a short piece sits in the original clamp.  You can use it for GPS, ipod, beer holder... etc the possibilities are endless.
loves ze desmodromics.
« Reply #7 on: December 17, 2009, 08:38:52 AM »
as Howie said, top triple is cosmetics. The aftermarket ones are a slight bit lighter and a slight bit more rigid, but will not substantially affect the rigidness of the bike (beefier lower triples do that).
tankerbutt
« Reply #8 on: December 17, 2009, 09:27:38 AM »
Or you can do something like this   waytogo
