Cold weather start...
Started by Qfactor, December 17, 2009, 11:33:51 AM
Qfactor
Any recommendations from Northern (Canada and Alaska) owners for cold weather start?
I have issues getting the thing started in the morning and late evenings.
Any tips and/or tricks? Block heaters? Throttle bodies heater?
I have been contemplating setting up a couple extra stick on grip heaters to the cases to induce some heat to the battery and throttle bodies. I read about this somewhere. Can't remember where tho.
thoughts? experience?
Q
Which year and model of monster?
How old is your battery?
FWIW, my 06 S2R1k doesnt start to well below 30. It takes about 4-5 cranks to fire up.
Qfactor
06 s2r 8
battery is roughly a 10months old... maintained properly (on the charger when in the garage). no way to plug it in @ work.
Q
Qfactor
I mean, no start at all...
Spins, spins, spins, cough cough ..spins spins spins cough cough...etc...
battery weakens enough before it'll start. Gauges sweep slower than normal.
Q
Qfactor
Triple J
Push it to some place warmer!  [cheeky]
No good info. here...other than to say my MTS1000 was always a pregnant dog to start below 35* or so...especially after sitting outside all day at work. It always did...but it was close sometimes, and I never really rode below 25*.
My Guzzi roars to life no matter how cold it is though.  [beer]
WetDuc
Try an O2 manipulator?  Are you still running the stock ECU?
S2Rs dont have O2 sensors.
Do you have a fast idle?
Ive tried to start my S2R1k in 10 degrees a few times. or even below that. its a pregnant dog. 10-15 cranks before it will even sound like it wants to start.
Dont know how to help you out. If you had a way to increase the fuel during start up that would be great.
Check out CA-Cycleworks sponsor page, there is something called AG Hammer Pulse Box. I was wondering what it was, and it may or may not help you in this situation.
Quote from: Qfactor on December 17, 2009, 11:33:51 AM
Q
Doood...
you're in MA.
Whatchou gonna do when it gets cold? [laugh]
LowThudd
This may seem strange, but what about a heating pad on or under the tank. If the fuel is warm, it might start better.
Q
AndrewNS
I'm up here in the frozen north (Canada), and my 06 S2R1000 actually starts pretty good in the cold. It seemed slightly better before I put the DP ECU on it, but even now it always catches if I crack the throttle just a hair while it's cranking.
And HeMan, I think a stock S2R1000 does have an O2 sensor. You only lose it when you splash out for the termi kit with the replacement ecu. Not that it makes much of a difference here.
Qfactor
S2r 800 here, no O2 sensor, just the fast idle.
Wouldn't start lastnight, as discussed above, not even a sputter or cough.
Started this am after 5-6 crank cycles. No tender or jumpers. Not sure if it'll start after a day of sitting in the breezy parking lot.
Motor temp finally showed a reading after 10mins warm up and 12miles of highway, went up to 132*, and didn't budge from there.
Q
