February 10, 2025, 06:24:26 AM
Please Help
OZ monsters
New chain option question
Topic: New chain option question (Read 1332 times)
Two dogs
December 19, 2009, 02:49:47 PM »
Hi again OZMO'S
can some one help me with some chain advice please
looking at these two below, which is better and why
or what else would you recommend for my M695/S
also 500 or 525 what is the difference
http://www.monsterparts.com/pc/EKSRX/Chain-Sprocket/EKSRX.html
http://www.monsterparts.com/pc/EKMVXZ/Chain-Sprocket/EKMVXZ.html
I am also going to put back the 15T front sprocket as it is still new and go up three teeth on the back with this
http://www.monsterparts.com/pc/735/Chain-Sprocket/735.html
They both seem good value and as I will be ordering something from monsterparts soon anyway it would seem to be value for $.
thanks and have a safe and happy Christmas to you all.
dez
Last Edit: December 19, 2009, 02:52:25 PM by dezmonster
cduarte
Re: New chain option question
December 19, 2009, 03:12:05 PM »
you want to stay with a 520 chain, the 695 isn't nearly powerful enough to think about a 525, which is heavier. Also, your stock gearing is 15/42, if you want to go back to the 15 tooth sprocket, you should consider a 44 or 46 tooth rear sprocket. I put a 46 on mine and it's much improved. Additionally, check out this link as it will show you not only the stock gearing, but how many links you need on your chain...
http://www.ca-cycleworks.com/shop/catalog/ducati/chain.html#DiD
chain
loony888
"I WAS GOING HOW FAST, OFFICER?"
December 19, 2009, 03:19:53 PM »
525 is heavier than 520, the 14t front sprocket will have caused accelerated wear of the chain due to the tighter radius, the 15t front and larger rear sprocket has merit, less wear on the chain and chain guide, less tension on the output shaft bearing. as for a chain, go for the best you can afford, there's X ring chains that are supposed to have less drag and seal well. Buying an expensive chain is no guarantee of a long life though, whichever one you get make sure you lube it regularly.
paul.
HERE AND NOW 12 DIAVEL AMG
93 888 RS
09 1098R BAYLISS
07 Husqvarna TE 450
GONE BUT NOT FORGOTTEN 03 S4R 95 900SL
01 S4 93 900M
96 748SP
FIFO
Doing the latter
December 19, 2009, 10:23:18 PM »
Hey Dez
The bigger chain will suck the power,and not necessary.
you will also need to use a 525 front sprocket.
Go for the EK 520MVX2 in gold.
And get a screw link then you or we can do it with out any special tools.(you can borrow my stand) too easy
http://www.monsterparts.com/pc/EKSCREWLINK/Chain-Sprocket/EKSCREWLINK.html
I got my chain from monster parts.
He had the best price and i like paypal.
Add a t shirt to that order 2xl ,will fix you up
http://www.monsterparts.com/pc/DMmens/Apparel/DMmens.html
dragonworld.
I can make like a tripod with my.....
December 20, 2009, 12:16:16 AM »
The old carbed 750 in the garage used to eat the 520 chain, it was not really up to the job, but once I changed to the 525 chain life was dramatically improved with a lot less time between adjustments.
Yes the 525 is heavier (not really that much) but in the real world, unless of course you are in the last 5-10% of your performance envelope, you wont really notice a loss in performance or suspension operation!
The 750 didnt lose any economy with the larger, heavier chain and chain life was much better, even with the old dinosaurs neck snapping, arm wrenching power output!!
[moto]
Last Edit: December 20, 2009, 12:05:49 PM by dragonworld
Two dogs
December 20, 2009, 10:25:31 AM »
Quote from: Rob s on December 19, 2009, 10:23:18 PM
Hey Dez
Sweet Rob!
Waiting on a part that is out of stock so don't know when it will be in ,also Matty wants me to add something for him too.
I gather the T shirt is in your size
it would be a good trade
We will have to organise an Old road cruize soon , my son would like to come up on his mini monster so a slow
pace run for him would be nice [moto] be it a little hard to control the right wrist
though but I can always just hang back with him and catch up with the pack at the cafe.
Dez
brad black
December 21, 2009, 12:19:34 AM »
Quote from: dragonworld on December 20, 2009, 12:16:16 AM
[moto]
that's quite interesting. did you change gearing or chain grade / sealing ring spec as well?
Brad The Bike Boy
http://www.bikeboy.org
