Torque Setting for Frame slider nuts??
Started by balerionbjj, May 28, 2008, 01:24:11 PM
balerionbjj
Anyone know the what the torque setting for the 12MM nuts should be tightened to when adding frame sliders?
Thanks,
Caleb
carlosbarrios
Either use the spec provided with the sliders (if any), or use the same as the engine bolt you removed:
http://ducatimonsterworldwide.org/index.php?topic=373.0
2V:  Engine mounting bolts                        40-45 Nm
4V:  Nut for engine-frame bolt  M12x1.5  60 *  GREASE B
balerionbjj
The frame slider website says 80Nm which seems crazy tight.
Quote from: balerionbjj on May 28, 2008, 03:16:27 PM
Are you sure that's not a "not to exceed" spec?  I think that's what my frame slider instructions had.
