How hot is hot
Started by Dockstrada, December 23, 2009, 03:00:00 PM
Dockstrada
Hey all, was in the man cave today putting a gold finish on the exhaust and noticed how hot they get  :o
Normal do you think  ???
Finished result  [bow_down] [bow_down]
If I wasn't who i was, I wouldn't be who I am !
bazz20
if they are very thin , other wise running too lean  [thumbsup]
craigo
That would make me nervous. Maybe it's supposed to have air running past it to keep it cool. If it's just sitting there on stands it would have to get hotter than normal.
mostro900
Wow! wtf! That seems extraordinarily hot. just keep your legs in check!
nice finish too!  [thumbsup]
03 M900
04 ET125
08 Sherpa
'when in doubt apply throttle' - it may not save you, but it will end the suspense
mattyvas
yep i'd say that's pretty warm there.
FIFO
That dull to glowing red would be about some were between 650c and 725 degrees c. ;)
Put it up on the main forum more tech heads there [thumbsup]
Vanman
Yep surprisingly normal.   Most bikes left running without airflow will get a good glow happening somewhere in the space of 5 to 15 minutes depending on tube thickness.     Its not a terrible thing to have happen, but something probably best avoided where possible.
Spider
Quote from: mattyvas on December 23, 2009, 06:42:18 PM
you my friend, are a frickin genius! new name MattyE.....the e is for engineer
;D
dragonworld.
Dannog
WoW how does the pipe go gold?
