LED turn signals?
Started by CCEMN1, December 29, 2009, 10:29:08 AM
CCEMN1
Can you retrofit LED turn signals on a 2007 S4RS without changing the blinler module?
Sorry about my ignorance guys, but I'm a newbie with my first Duc.
"I try to be a warrior, like my heroes, and writing is just one blade on my Swiss Army Samurai Sword." Ken Kesey
Hmm don't seem to have anything in our tutorials section. I'll have to check that out more, later.
Short answer - yes
long version - you cannot change the flasher relay on your bike, so don't worry about it. That relay is an integrated part of your dash electronics. Unless you're an electrical engineer it's not possible to alter it. It's only the pre immobilized bikes that have flasher relays that could be pulled out
The blinkers will work fine regardless of that. They will cycle faster than stock, if you have LEDs front and rear. If you want to bring them back to the stock flash rate you add some resistors. The most common set up is to wire them in parallel to the rear signals and secure them under the seat. BTW I've got a set of the right resistors already wired with bullet connectors that I'm trying to sell out of my parts bin. PM if interested
Many aftermarket turn signals look out of place on the stock beer tray, so unless you're chopping - how about this while you're working on the signals.....
http://www.monsterparts.com/pc/ZU-C010EDM/Bodywork-Carbon/ZU-C010EDM.html
superjohn
I installed aftermarket LED's front and rear and Yuu's right. They start blinking at the stock rate, but then speed up to approx twice the stock rate.
I'd like to think the extra blinking, and brightness is more noticeable.
CCEMN1
Yes, I plan on chopping the rear subframe and installing a set of your CNC aluminium plugs (I called you guys today & never got an answer or call back?)
I also share SuperJohn's feelings about the blink rate, but I'll have to see just how fast first. A also run a brake light flasher, for the same reason.
Thanks guys!
Be aware that the resistors get *quite* hot, I've repaired melted insulation on wiring from a poor install.
Quote from: CCEMN1 on December 29, 2009, 05:19:23 PM
Thanks guys!
who's you guys? If you are referring to the link Stopintime gave you, he's not with them.
oh, ya gotta change your avatar... i'm getting horny everytime i see it.
CCEMN1
Oh, I thought he was one of the sponsors, "Monsterparts.com" Great site, but I can't get anyone to answer the phone? Probably on vacation.
Well any if the sponsors are just sponsors and there's s bunch of em. Some do haunt the board, but not all. Tis holiday season so they might be off. And if you're new to Ducs do not try to get stuff from italy in august.
CapnCrunch
I might be building some... I'll keep you posted.
you are thinking of an LED board just fitted into the stock housing right?
al@sktc
i just ordered a bunch of parts from monsterparts and jeff was cool. if he doesn't answer leave a message. he always returns call promptly.
