Opinions - 45t to 47t sprocket M696
Started by DucatiSTi, December 30, 2009, 01:59:57 PM
DucatiSTi
I am thinking about changing the rear sprocket on my M696 from 45 to 47 teeth
Any experience/thoughts with this change?? - I should get more torque but lose top end
BTW I have the 14t on the front
Also, should I go with the DP sprocket or aftermarket (I can get PBR sprockets cheaper)
One last thing - Is the chain long enough?
Thanks
2009 696 Monster - Arrow Carbon slip-ons, Bitubo steering damper, DP oil cooler, DP Touring Seat, Rizoma tail chop, Rizoma Zero 11's, Stebel Nautilus horn, Ducati Euro shroud, Speedymoto sliders (axles and frame)
herm
i think common wisdom is that you do one or the other (down in front, up in rear) but not both as they both do the same thing.
of the two, i have also heard that going up on the rear is the better (but more expensive) choice. cant remember why....
No more Monster.
DesmoReynoso
#2
I too have been thinking of going up in the back and have been reading & asking around so this is just MY thoughts based on what Ive heard as I haven't done it myself yet.....
It IS more expensive to go up in the back and more labor intensive, also you DO loose about 10-15mph on the top end and you WILL have to buy a new chain (length) even with the back wheel adjustment all the way in + the size of the 47T sprocket is almost the diameter of the back wheel's rim so some people don't like how it looks....
My thoughts on the above are to just go up to 46T in the back which I think & based on the gear commander online site would help with the rpms in low gear & around town without sacrificing so much of the top end and the added wear of changing the front sprocket. Granted you probably won't feel it as much (the illusion of added torque) + you won't get to the rev limiter as fast when cruising in highways (something good at least for me).
I'm still undecided as I really don't have too much problems with driving the 696 around the city and in stop & go traffic the way it comes stock and would hate to have 125/130mph as my top speed! So if I did end up doing something to it, probably will be very minor and not something as noticeable as 15T to 14t front or 45T to 47T in the back....
Hope this helps, also you might want to check the gear commander website http://www.gearingcommander.com/
Whats your experience so far with 14T in the front? Are you happy? What's your riding style and primary use for the 696?
If you find yourself calling others nasty names on the internet, step back and examine your life. - MeterPig
One man's dreams can be another man's reality, make the beast with two backsing deal with it! - Me
DucatiSTi
Quote from: preynoso on December 30, 2009, 03:23:51 PMWhats your experience so far with 14T in the front? Are you happy? What's your riding style and primary use for the 696?
The 14t on the front really smoothes out first gear - I recommend it I think everyone on the DMF does as well
on occasion, I drive in the city but I prefer the open roads
Thanks for your input
Nothing mysterious, just math...
Your 14T front makes your bike run at 6.67% higher revs at all times.
45 to 47 rear sprocket adds another 4%.
Loss of top speed? Most likely, your bike and you are limited by air resistance before you hit the rev limiter. It shouldn't be too hard to establish the facts - if you know your rev limit, you try to reach that under safe conditions in 6th gear.
If you can, the 45/47 mod will limit top speed. If you can't, the 45/47 mod won't limit much either.
ahh the gearing and top speed problem...
i ran a 14t and hit 212kph on the speedo (hitting stock ECU rpm limiter, not air resistence) with a corrected speed of 121mph losing about 10mph top end.
after my engine work i'm going back to 15t, and possibly a scary 140+mph top end with some aero aids and a new higher rpm limit of 10500. look out 620 capirex!
Quote from: Raux on December 31, 2009, 01:22:55 AM
What's the stock ECU / DP ECU limits on the 696?
What do you mean by "corrected speed" and how do you know that you lost 10mph?
Quote from: stopintime on December 31, 2009, 04:30:36 AM
stock/dp 8500rpm/10500rpm
actual vs indicated is 8% per manual.
i never did test the 15t top end though but others have indicated 130-132
Quote from: Raux on December 31, 2009, 04:36:58 AM
Wow - that's a good reason to get the DP ECU. On my S2R 800 I think it moved from ~8,500 to 9,500.
At indicated 220km/h (138mph) I'm at ~8,500, so both bikes are in the rev limited top speed range with stock ECU then.
The corrected answer to the OP would, I guess, be that 45 to 47 mod will limit his top speed.
Quote from: stopintime on December 31, 2009, 04:44:38 AM
don't quote me on the 10,500 since i haven't test it yet. interestingly i've read the stock is 9000 but fuel cutout at 8500 or so.. not a nice feeling but at least in a straight line manageable.
Quote from: Raux on December 31, 2009, 05:04:36 AM
I think it would scare me going 130mph+  :o
Quote from: stopintime on December 31, 2009, 05:16:13 AM
yeah me too, but someone's got to.
DesmoReynoso
Quote from: Raux on December 31, 2009, 05:36:57 AM
I've hit 137mph going by myself on the M696 and couldve hit 140 probably but had to stop accelerating since there was a corner coming up, I was riding with 3 other guys that where on 1000c Ricerockets. With a passenger on it was hard keeping up with them, but once the passenger switched and I was solo they where catching up to me.....
One of the main reasons I haven't yet jumped on gearing to 14T front or 47T back and think that maybe just going +1 in the back could be a ver subtle yet effective solution.
Quote from: preynoso on December 31, 2009, 09:42:43 AM
so speed corrected that's about 126mph. which seems about right if you had a bit more.
DesmoReynoso
Quote from: Raux on December 31, 2009, 10:30:45 AM
Yep, sounds about right. The other thing I didn't mention is you really have to tuck yourself as low as you can because the wind force against you is really bothersome and come up the gears revving up to round 9000rpms right before the red light comes on (it comes on as you're pulling in the clutch to shift) and then you have plenty of power, easily gets to 130mph (once corrected).
[thumbsup]
